Question about Magic Chef MCBR440 Compact Refrigerator
My 3.6 cuft Magic Chef frig quit over a weekend. When I plug it in, the compressor is not running and is getting very warm. Is there any quick/inexpensive fix?
There's a small compressor starter that can be replaced. i had similar problem and it seemed to work. the bad starter could be a result of an underlying compressor problem though. for $40 i took a chance and all seems fine so far. the starter simply plugs in and is found under the electrical cover on the compressor. my pt# was P6R8MC, and the starter was black in color. be sure your unplugged first.
Posted on Nov 13, 2010
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
Compressor is hot, but will not start. Just keep hearing a relay / contact clicking ebery few minutes.
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
Oct 11, 2013 | Magic Chef MCBR360S Stainless Steel...
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
Magic chef portable freezer not cooling. compressor running
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
Dec 26, 2010 | Magic Chef Chest Freezer MCCF5WBX
My Magic Chef 5.5 cubic chest freezer with manual defrost, just quit working. It was a year old this March and it stopped working this July. The power light is on, but run light is not. We unplugged for 5...
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
Oct 30, 2017 | Magic Chef Chest Freezer MCCF5WBX
I have a magic chef refrigerator model number ctb1922ar. It will stop working and everything will defrost, I unplug the refrigerator and plug it back in and turn the control off and then on and the frig...
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Magic Chef CTB1922 Top Freezer...
It wont cool
if the compressor is running your ref. should be getting cold.their is a defrost timer but when it is in defrost the compressor shuts off.I think you do have a leak.
Mar 20, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Compressor cutting out about every 30 to 45 sec
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Jan 12, 2009 | Magic Chef CTB1922 Top Freezer...
Magic Chef MCBR440 Compact Refrigerator Logo
971 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
