Question about Frigidaire FRS23H5AS Side by Side Refrigerator
The ice maker stopped ejecting ice. Now no water going to icemaker
First the ice maker quit ejecting ice. Didn't do anything about it for over a year. We just used ice trays. Thought it was a hard water issue. Now we have RO water going to fridge and want an ice maker again. Took the ice maker out and cleaned it with vinegar and water. Put it back in. No water going into the tray. Is the water valve shot? Checked all the lines for freezes. None. Is there a sensor that tells the water to fill the tray? How does the damn thing work? I've notice that this seems to be a common problem with this model fridge.
  • lotusbee Jun 19, 2008
    Really no help.
  • 497 Answers
Hav u cleared the ejection area for any debris and the like?
Posted on Jun 14, 2008
  • Yaz  S
    Yaz S Jun 14, 2008
    An ice making mechanism includes a tray for receiving water to be frozen into ice bodies, a sensor for determining whether the water is frozen, to initiate an ice-ejecting mode, a motor for rotating the tray to perform the ice-ejecting mode, a switching mechanism for indicating a state of the ice-ejecting mode, and a switch actuating structure driven by the motor for changing a state of the switches during the ice-ejecting mode. When an ice-ejecting mode is initiated, a time period for the state of the switching mechanism to be changed is compared with a reference time period. If the state of the switching mechanism has not been changed within the referenced time period, the ice-ejecting mode is stopped, and the tray is returned to an up-right position. Also, an alarm signal is generated indicating to a user that the ice-ejecting mode has been stopped.
  • Yaz  S
    Yaz S Jun 14, 2008
    To Connect Water Supply Line To Ice Maker Inlet Valve 1. Disconnect refrigerator from electric power source. 2. Place end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shut off valve. 3. Unscrew plastic cap from water valve inlet and discard cap. 4. Slide brass compression nut, then ferrule (sleeve) onto water supply line, as shown. 5. Push water supply line into water valve inlet as far as it will go (¼ inch). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten. 6. With steel clamp and screw, secure water supply line to rear panel of refrigerator as shown. 7. Coil excess water supply line (about 2½ turns) behind refrigerator as shown and arrange coils so they do not vibrate or wear against any other surface. 8. Turn ON water supply at shutoff valve and tighten any connections that leak. 9. Reconnect refrigerator to electrical power source. 10. To turn ice maker on, lower wire signal arm (see ice maker front cover for ON/OFF position of arm). for further assistance a fellow member has posted a tip
    please check wth this too
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Ice cube ejector bar keeps freezing preventing ice from ejecting to tray
Replace your water valve part # WR57x10032, from what you have listed above you have a bleeding water valve allow water to enter the ice maker mold. The valve is not closing completely. This part show fix this issue for you.
Good Luck
Mar 30, 2014 | General Electric GE GSS25GFXWW (25.0 cu....
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
Mar 03, 2017 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
After replacing ice maker assembly, ice is not getting made?
Ice maker is leaking water and causing the ice to freeze?
Ice maker is noisy and not making ice?
Refrigerator ice maker stopped making ice?
Ice maker leaks water into ice bin causing a glob of ice?
Amana Refrigerator leaking water from ice maker?
Ice maker leaking?
Ice maker is dumping the ice cubes out before frozen solid.
Water overflowing ice maker?
Ice cube is getting stuck up hard in ice maker
Icemaker quit working?
Quit making ice
Water leaking into ice tray, frozen glob of ice
Not making ice, and water leaking in freezer?
The ice maker stopped making ice?
Ice maker not making ice?
Ice maker quit working?
Ice maker dispensing black pieces of plastic in the ice?
Replaced Ice maker but its still not making ice?
Ice maker leaked creating an ice block?
Ice tray leaked?
Ice maker stopped functioning?
Ice maker stop working?
Ice maker failed
Old ice maker stopped working?
Old ice maker started leaking?
Ice maker not working?
Ice maker overfills and cause water to flow into ice dispenser and freezes?
Ice maker didn't make ice?
Ice maker was leaking?
Ice maker was leaking after it filled up with water?
These will help.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve ( - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
413 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
