Question about Whirlpool Microwave Ovens
Sparking inside. Little mica cover got a hole
    Genius:
  • 1,036 Answers
Hi there.
Unfortunately this is how most microwaves die. The Magnatron that generates the microwaves (behind the cover) overheats and charrs the insulation between the high voltage contacts.
You would be best to obtain a new unit or have it repaired,
Spares are usually available, but sometimes it is not economically feasable.
Hope this helps.
Posted on Jun 14, 2008
Massive sparking and noisy when switched on to heat
There are 2 things that cause the massive sparking:
1. you placed inside the microwave oven a metal plate or one with silvery or golden drawings;
2. the mica sheet that covers the magnetron window is compromised (has holes, it is cracked) or it is covered with burnt (carbonised) food.
You have to carefully inspect the mica sheet and wash or replace it, if necessary. Hope that helps.
Regards,
Dan
Oct 10, 2016 | Microwave Ovens
Hole burned in panel inside next to ligt
take it in for repairs or just replace it
Apr 26, 2015 | Sharp Microwave Ovens
Is the mica cover crucial?
sad to say but YES it is critical . .
Mar 25, 2015 | In Microwave Ovens
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
Aug 25, 2014 | Sharp Carousel R530EST Microwave Oven
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
Sparks are coming from behind the little revovable plate inside the oven.
these covers are made of a mica material; and tend to get grease-soaked from food splatter. this is where the microwaves pass through. if cover is burned, you will need to replace and clean greasy mess underneath. hopefully, the magnetron is not damaged.
Aug 06, 2011 | Jenn-Air JMC9158AA Convection Microwave...
Maytag over the range micrwave is intermitely sparking when in use otherwise working well.
If there is carbonized food on the plate or wheels for the turntable, that will make it spark as will a contaminated Wave Guide Cover. Yhe mica cover that protects the magnetron from food debris and steam. Check the cover is not arcing on the inside.
Feb 07, 2011 | Maytag Appliances Over-the-Range Microwave...
I dont have and enlish manual. It shows two items inside called Tampas de Mica. Are these supposed to be there or should they be removed
I do not have an English manual, but maybe if you posted a brand name and model number I could try to find one for you.
"Tampas de mica" in Portuguese translates to "mica cover". If these coverings are inside the oven cavity they are supposed to be there. Mica is a dielectric material that resists the flow of current. In a nut shell, they act as insulators to reflect RF energy inside the oven.
If you have questions, please let me know. I hope you find this information helpful.
Aug 14, 2009 | Microwave Ovens
I need a microwave guide cover for model mw8115ss
Buy a sheet of mica. It's cheap and easy to work with. Draw and cut a new cover from a sheet and replace the damaged one. There's a example of how cheap mica is (I just used a sheet like that today on my Miele microwave).
http://www.leiritronica.com/linhabranca/product_info.php?products_id=2587
Don't try punching holes in mica, always drill them gently. It will easily flake.
Mar 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
Microwave Ovens Logo
360 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
