Question about Ovens
The oven will not ignite. Pilot light does work. Was recwntly changed to LP gas. worked before chane to LP gas.
  • areomax Nov 07, 2010
    I have aBakers Pride X500 Convection oven. The pilot light is working but the main burner will not ignite when you turn on the unit. The oriface was replaced to go from NG to LP. It seems that the gas is shut off. Could it be a weak thermocouple?
  • areomax Nov 09, 2010
    The oven was converted to LP. by a shop. Because I live in such a remote area service is next to impossible unless I pay someone more than 3X the value of the oven. Right now phone service is very poor for me as I am on radio phone and it is snowing like mad. Even my internet has been going off nd on as I have to go and sweep of the dish continuously, and its a hassle in the dark. Anyways gas is off. But I think it may be a weak thermocouple.
    Genius:
  • 1,340 Answers
IF THIS OVEN WAS PREVIOUSLY USED FOR NATURAL GAS,PLEASE DO NOT ATTEMPT ANY MORE USE!!!YOU NEED AN LP OVEN!!! IF YOU WOULD LIKE,I AM IN USA AND CAN CALL YOU OR WILL GIVE YOU MY NUMBER!!!PLEASE TURN OFF YOUR GAS!!!
GREG 727 584 2554 UNTIL 11PM EST
Posted on Nov 08, 2010
  • Greg McCarthy Nov 09, 2010
    Seriously,all the lines and burners need to be changed.There is NOTHING compatible between the 2 gas systems.NOTHING.That is why they have 2 completely separate ovens.Natural gas is gas.LP is a liquid.That alone requires different size tubing,different size holes in the burners,everything.The gas regulator.The 2 gases have completely burn characteristics,densities,and are just 2 completely different things altogether.That is why you will only get a pilot light for one thing.Gases are not universal.If they are,why don't you just burn gasoline in it,or kerosene?It is cheaper than LP.I guarantee if you change it all out,your oven will work fine.I have no idea who you had change it out by just using the orifice as a change,but trust me,it is very wrong.You can find out for yourself by googling LP vs. natural gas or by posing any question regarding their compatability.Seriously.I have had formal training on designing and repairing these things.Greg
    I got cut off.Even if you do not change the holes,you have to change the flame settings.If there is one,there should be a small screw in the burner to adjust the flame range.Although the orifice changes the pressure of the LP,the burner also needs fine tuning.That would be another reason to not get past the pilot.Most stoves have a fairly small setscrew,too small for a regular size screwdriver tip.Since there was no mention of it,I just wanted to make you aware.Just stating that it was converted to LP,with no mention of a shop,I was really concerned about if you just did it yourself with no help or knowledge,so I do apologize sir.If you are sure all of that was done,then yes I would go with the thermocouple.Also,the thermocouple would be either good or bad.I am not sure what you mean by weak as I do not know where you are.They don't really partially work.Greg Sorry to hear of early snow too :(
  • Ovens Master
  • 8,220 Answers
You must adjust the orifices on some models known as crank down and flip models. Newer models must have orifices replaced. If you cranked the spud on the oven's gas safety valve all the way down you might have choked off the gas completely. Back off the orifice a little till the gas comes out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 04, 2010
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
Pilot light keeps going out when turning on oven
Sounds like the GSD. The Gas Safety Device valve needs replacing
Oct 17, 2017 | Ovens
How do i change from lp gas to natural gas on wall oven
First thing you will need to do is find out from the manufacturer of the oven if there is a conversion kit available and if the appliance is convertable. If there is then you can order the kit and follow the installation instructions. Also check the back of the oven for an envelope that may contain the gas orfice replacement heads to convert the appliance to natural gas. If you find the replacement orfice then you will need to remove the lp orfice from the burner and install the natural one. Then the appliance gas regulator will need to have the pressure adjusted lower for natural gas. There is usually a removable cap on top of the regulator on the oven. When you remove this cap there is usually a small metal ring that you can remove and flip over. It will say "nat" on one side and "lp" on the other. You will need to turn this ring over and re-insert so it displays "nat". This will change the gas pressure from 13 inches W.C. to 4 inches W.C. Some appliances only require the orfice change and no regulator adjustment but make sure that is the case with your oven because if you feed 13 inches W.C. pressure to a burner with a natural gas orfice...YOU WILL GET A HUGE BURNER FLAME AND MAY BURN/FLASH YOURSELF...So use extreme caution when converting a gas appliance. And if the oven has a pilot you will need to adjust the pilot pressure or change it's orfice if it has one. If it is electronic ignition no adjustment to that will be needed. Also unplug the electrical power the the unit while working on it.
Oct 11, 2009 | Ovens
The pilot light works and gas in oven is on, but no gas ingition
bad thermal bulb, try moving the bulb into the flame more.
Jun 25, 2009 | Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Gas oven will not ignite
It sounds like somebody bypassed the flame sensor on the oven, no oven should ever release gas for more than a couple seconds if there is no ignition. This oven is very dangerous and should not be used until it is looked at by a professional.
Dec 19, 2008 | Ovens
Pilot flame starved out after burners ignite
The declining pilot light might be an indication it is being starved of oxygen by the main burners or some other sort of circumstance.
I have noticed how in a closed room without ventilation the pilot light soon begins to decline and then springs back again when a window or door is opened while the main burners are hardly affected.
This is the gas equivalent of sending canaries down coal mines and is an essential safety feature. If the pilot light declines very much the thermocouple bulb will not be heated and the gas supply to the main burners will be cut off. This is why the pilot light is set at an angle and the thermocouple bulb is slightly offset.
I am not sure if this helps but I hope it does.
Mar 08, 2017 | Ovens
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Maytag MGR5775QDW-TOP works ,broiler and oven don't
If you have lp makes sure the tanks are fill and unit is converted to lp.Same goes for natural gas
Nov 06, 2008 | Maytag CWG3100A Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
106 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
