Question about Maytag Washing Machines
Our washing machine wont spin .The water pump is pumping the water out but the barrel is not spinning the model is MAF1300AAW can you please advise .
  • irld Jun 14, 2008
    none of these seem to be the issue. have removed the back to check the belt . one red terminal seems to be arking and loose. plz advise
    Master:
  • 497 Answers
How long have been experiencing this problem
Posted on Jun 14, 2008
  • Yaz  S
    Yaz S Jun 14, 2008
    this model has already encountered such problems with other users...i guess u take it back to your dealer and get it checked out
  • Yaz  S
    Yaz S Jun 14, 2008
    1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Sometimes you can just open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Just close the lid and retry.
    2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn’t click when you press and release it, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
    3) The belt may be loose, worn, or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
    4) There may be a problem with the controls; in this case, call an appliance repairperson.
    Check out these tips too
Hi, my lg turbo drum WF8071TTP does not drain and spin, the spin light flash. please advise. thanks.
check pump for blockage or faulty,if water doesnt drain machine wont spin
Nov 01, 2017 | LG Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My kenmore washer fills but wont pump the water out. it washes and spins, but i have to **** the water out with my shopvac. the drian hose is not clogged or kinked. could it be the water pump?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 14, 2011 | Washing Machines
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
heatman101
Nov 12, 2010 | Kenmore Washing Machines
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
