GE Security Simon 3 Wireless Home Security System
Problem for GE Security Simon 3 Wireless Home Security System
Simon 3: A remote window sensor downstairs creates a constant Low Battery beep/message.
By Anonnymoose on Jun 14, 2008
I ordered a new SAFT 3.6 v replacement battery, and no improvement. The old sensor battery lasted 3 years. Suddenly 2 weeks ago it began to beep every six - eight hours until the Status button was pushed:
"Sensor 13 Downstairs guestroom window. Low Battery."
Sensor 14 is identical and is placed on an adjacent window. It has not reported a low battery ever. I replaced both sensors' batteries today, and now, fifteen minutes later, everything remains exactly the same. Is this likely a sensor failure, sending the wrong message to the Simon 3?
Same Problem
Jul 27, 2008
-   Having similar problem. Replaced all door sensor batteries and still get low battery signal. Believe battery in main unit needs to be replaced. Does anyone know the battery number-   Guest
Best Solution
posted on Oct 17, 2008
Very Helpful)
doctorgonzo7
Rank: Guide
Rating: 90%, 6 votes
you have to run a sensor test so the system will recoginize the new battery, open keypad cover type in your code press test till it says "sensor test" once it runs through all points press done, now reset your panel disarm code disarm
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2008
Not Rated)
coco_lee
Rank: Apprentice
Rating: 0%, 0 votes
Open Circuit Voltage: 3.67 V
Nominal Voltage: 3.6 V
Nominal Capacity (drain): 3.4 Ah (4 mA)
Max. recom. cont. current: 130 mA
Operating temp. range: -60/+85C
Outside diameter max: 17 mm
Length max: 50.9 mm
Weight: 23.5 g
Transport: Non restricted
Pls visit www.whforte.com China lithium battery manufactuer Contact: coco_lee@wh-forte.com Tel:86-13986282065 Tel:86-027-83258996 ext 8009 Fax:86-027-8325920
Was this helpful?
Yes
No
Solution #3
posted on Sep 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the capacitor in the sensor is faulty, you need to replace the sensor.
Solution #4
posted on Aug 05, 2008
Not Rated)
knockhimoutj
Rank: Apprentice
Rating: 92%, 5 votes
it should be a 6 volt, 1.3 amp hour battery. you can get them at batteries plus. best bet is to take the old one with you to the store to ensure that it fits.
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
Questions and Unsolved Problems for GE Security Simon 3 Wireless
Do you recommend GE Security Simon 3 Wireless Home Security System?
Answer
Answer
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code... (More)
Answer
we have had a gemini security system but have not installed it. Then, the baby in the house pressed... (More)
Answer
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I... (More)
Answer
how do you replace the battery for the vista 15pmt system. I have the low battery light
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Security Simon 3 Wireless...:
Top Security System and... Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Security System and... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
