Question about John Deere Garden
I had been using ethanol gas and ran into the tractor dying. I emptied the tank and am using non-ethanol. I cannot get any fire even with starting fluid. I have replaced the spark plug and am getting spark. Any ideas as to what may cause it to no longer fire and start?
SOURCE: Trouble starting Craftsman Lawn Tractor Mod# 917-272350
It is time to rebuild your carburetor paying special attention to the float and seat.
Gasket set is about $30 delivered and gallon can of gunk carb cleaner with a parts basket is $21 at kragen auto parts. takes about two to three hours. Or you can but a new carb for about $150.
Posted on Jan 29, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Posted on Jun 08, 2009
  • 11 Answers
SOURCE: Model 180 John Deere garden tractor won't start
*cyliniod sticking... try banging on it with the blunt end of a good heavy screw driver / or the handle of a hammer. might free up the contacts, or it might be too rusted inside...
*yes to the first part about starting fluid...the starting fluid should have fired off the motor for a few seconds...so since you didnt get anything after this, it sounds like your not getting adequite fire to the cylinder (s) .
i would try a new spark plug since that would be the cheapest thing to start with first.
Posted on Jun 24, 2009
huffman49
  • 235 Answers
SOURCE: ys4500 Lawn Tractor will not start.
did you hit something while mowing if that is the case then check the flywheel key. even if it only has a small nick in it that would keep the engine from starting up...good l uck
Posted on Apr 11, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
Husqvarna kohler courage 20 hp wont start
Not sure what you meant by starting fluid didn't make a difference. If it fired (tried to start/run) after using starter fluid, then fuel flow is the problem. One technique I've used to troubleshoot a mower someone gave to me, is to place my hand over the air intake of the carb and see if I can keep it running by choking with my hand. For me, its worked, and basically it proved that the carb was bad. If this works, then try cleaning carb...replace needle valve and float if necessary. A repair didn't work for me, had to replace whole carb ~$80. If the solution is a repair is to the fuel system...do not spare expense in the future on using NON-ethanol gas or good additive that neutralizes the effects of the ethanol. Small engines, especially ones not used daily, will suffer damage from ethanol gasoline. A cheap price to pay for the aggravation your going through now.
Apr 09, 2014 | Husqvarna Garden
Starts but dies
run fault codes to find which sensor is faulty --check for MAP/MAF sensor problems.
Nov 17, 2013 | 1999 Ford Ranger SuperCab
HARD TO START THEN ACTS LIKE ITS STARVING FOR GAS. ALREADY REPLACED PLUGS, FULE FILTER AIR CLEANER.
Had problem like this check the graumet for fuel line pick up tube that goes in fuel tank if it is deteriorated losses vacuum check inside fuel lines put clear fuel filter if it dont stay above half full the line could be restricted if your not using no ethanol fuel and always premium non ethanol fuel . Other will make fuel lines i.d. shrink take pick up tube out of tank see if any black stuff on bottom of tank if so replace all lines pump clean tank rebuild carb buy only premium no ethanol gas
Jul 02, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My pro user g5000 generator wonts start after being stood for 6 months any ideas
Hello John, Your gas more than likely has gone bad. If you have spark and good compression and it won't start then chances are the gas has gone bad. Today's gas contains about 10% ethanol, which is absolutely terrible for small engines. Gas with ethanol has a max shelf life of about 90 days under perfect conditions. A month or less is more realistic. Here is the problem, ethanol absorbs water and sits at the bottom of the tank in the generator. If You have a 5 gallon tank With 10% ethanol then 10% times 5 gallons equals half a gallon of water saturated ethanol sitting at the bottom of the tank, I don't care what kind or how good an engine it is, it won't run on water saturated alcohol. Here is a great video explaining it. http://www.youtube.com/watch?v=YeCyFxoWPpo So what I would suggest is to drain the tank and the carburetor bowl of all the old gas. Replace the bowl and check for leaks. While everything is empty I would suggest that you replace the fuel line with a Tygon line. Tygon is resistant to ethanol. I would also ad a see through inline fuel filter and a new spark plug. After this is all done, put in a small amount of gas, less then a half gallon and see if she fires up. If it fires up right away you should be all good to go. Let the generator run until it's completely empty. And store it empty. Here are some problems and solutions that I have for gas with ethanol. I live in Savannah Georgia and the high humidity during the summer can ruin the gas in my lawn tractor in less than 2 weeks due to water saturation. The tractor is almost impossible to start and runs terribly until the remaining gas is used up. I have stopped filling the tank completely and I use just enough gas to cut the lawn then I store the tractor almost empty. I also use gas cans made by a company called Blitz. These containers are pretty much airtight and do not allow the ethanol to absorb water. This has made a tremendous difference in engine performance. Another thing that you can do is to check out this website http://pure-gas.org/ If you are lucky , you might have a gas station that sells gasoline without any ethanol added. This type of gas has a much longer shelf life and if a product like Stabil is added, you might get over a year of safe storage of gas for your generator. Municipal airports have banned ethanol in aviation gas and so have most marina's. It might cost a little more but it sure is worth it when the lights go out. If you can't find pure gas then I suggest you store gas in the Blitz containers for about 3 to 4 months. If you don't need to use the generator then use the gas in your car and refill the Blitz tanks again. Better safe than sorry. I hope this helps and if it does would you please be so kind and give me a positive rating for my solution. Good luck and thank you, Michael Burke.
Jan 04, 2012 | Coleman Electrical Supplies
Gas ratio for a weedeater XR50
the listed 40:1 ratio works fine but 50:1 has been my usual mix. Important - use non ethanol gas E0 or gas that has chem ethanol modifier. (Pilot brand Gas works) When finished try to run it out so the carb is empty. Even a dead start with quick start to clear all fuel. Easy mixing is to measure a 41 oz marked bottle. Add 1 oz of best two cycle oil then fill to mark.liljack
Aug 16, 2011 | Garden
2002 caravan stalled, faulty gas gage added fuel ran for 2 blocks, stalled added 4 more gallons non-ethanol - no start checked fuel pump fuses & relay had towed 2 miles - started fine! ideas?...
Looks like your fuel supply line has got chocked. This happens when the dirt from the gas tank comes into the fuel line when the tank is getting empty as it has happened in your case. Check your fuel filter and replace if required.
Nov 15, 2010 | 2002 Dodge Caravan
Filled up gas tank and gauge still shows empty. I
ethanol fuel effects the fuel sending unit ,even just 10% ethanol.New sending units from gm adress this.
Jun 18, 2009 | 2005 Buick Terraza
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Garden Logo
160 people viewed this question
Top John Deere Garden Experts
Wayne Fellows
Wayne Fellows
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Are you a John Deere Garden Expert? Answer questions, earn points and help others
