Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Motor loud I have a dyson dc17..recently when i turned it on and pulled the handle down to vacuum the motor was very loud..put the handle in the upright position it is quiet.any suggestions?
  • 77 Answers
When you put the handle down it turns on the brush roll. you may need to clean the brush roll or replce it if the bearings are bad.also clutch and 2 belts are started when putting handle down for brush operation.
Posted on Jun 14, 2008
Why want beater bar turn on Dyson DC17?
There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
Jul 09, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Why would my dyson dc 17 brush motor be extremely loud, but sound normal when brush is not spinning?
could be the bearings on the end of brushbar need replacing,or it may be the clutch needs setting , lower the handle down to the floor then up again do this about three time to reset clutch....
Nov 13, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a dyson dc17 animal. When you put the handle down, it is very loud
When you lower your DC17's handle into the vacuuming position, a second motor which powers the brushbar will switch on, which will make the machine sound a little louder than when it's standing upright.
However, if you're concerned that the noise the cleaner is making is unusually loud, I'd encourage you to get in touch with us directly - we'll be able to run through some troubleshooting checks over the phone to help resolve this.
You can reach us on 1-866-693-9766 - or if you email your contact details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 25, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
When I pull the handle down on my DC17 the motor goes quiet and then turns back on when I put the handle back up.
I'm sorry to hear you're having difficulties with your DC17. The problem you're experiencing sounds unusual, so it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to determine the best way to resolve this issue as quickly as possible.
You can call us free on 1866MYDYSON. We'll look forward to hearing from you.
Kind regards,
Jack
Oct 06, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Jul 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson DC17 animal vacuuum. Recently got
you need to check the clean out ports 1 directly under the hose on the bottom and the other where the removable filter is
Jan 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I can not get the handle down to vacuum, it is a dyson DC27
Step on the floor head where the foot print is and pull the handle down.
Mar 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 will not turn on unless the handle is pulled back.(into the vacuuming position) The attachment hose will not work at all (0 suction thru it). I've checked the hose and made sure there is no...
Not sure if I can help, but I'll try. The DC17 has two motors: the vacuum motor and a separate motor for the brush bar. It is normal that the brush motor works only when the handle is pulled back in the vacuuming position - that's the way it's made. So, when you say "my DC17 won't turn on", I'm not sure if you mean the vac motor, the brush motor, or both. If the vacuum motor won't turn on, then you've got a problem I can't help you with.
As for no suction through the hose, I have to ask... are you sure your vacuum motor is working at all? Even with the hose stored away, the machine still relies on suction through that hose. If you're sure the motor is working, then either you've got a blockage that you haven't yet found (there's at least one inspection port, a sort of U tube at bottom right of machine, that you need to check), or it could be that you've got a hole in the flexible hose (which opens only when the hose is extended).
Sorry if this is a bit garbled, but I'm puzzled by your problem. If you want to come back with more details I'll try again for you!
Feb 17, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
713 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
