Question about Dewalt D55146 Heavy Duty 412Gallon 200PSI Heavy Duty Hand Carry Compressor with Wheels
My compressor comes on but wont build pressure.
  • Dewalt Master
  • 885 Answers
If your motor works fine and you don't get any pressure buildup your problem is likely one of two areas. Under the head is a valve plate assembly (PN-A09819) that may have one or more broken reed valves. If the reeds are OK check the wiper on the piston. Sometimes a piece will break off of it or it may have come out of the groove on the piston. This part can only be bought as a connecting rod/piston assembly (PN-N038785)
Posted on Nov 04, 2010
My 60 gallon kolbalt was running and stop when it filled now it wont go o ever with the tank drain it spins free it does nothing no sounds either
When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
Oct 10, 2016 | Kobalt 3.7-HP 60-Gallon 155 PSI Electric...
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
My craftsmen air compressor wont build pressure. How do i fix it?
If the unit will not build up pressure you need to remove the compressor head from the compressor and inspect both the intake and the exhaust reeds as well as the piston ting on the compressor.
Without the model number of the compressor this is about as far as I can help with.
Sep 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Syltone compressor wont run after engaging pto wont build air up to pressure
at the main tank u hav a feed pipe coming out from a valve take off end pice and clean and oil releaf valve make sure spring isint broke
May 21, 2010 | Air Tools & Compressors
Compressor runs but wont build pressure
You are probably leaking past worn rings and/or through dirty or broken reed valves. You don't mention a make or manufacturer. Contact them for repair parts.
Thanks for your interest in FixYa.com
Feb 23, 2010 | Air Tools & Compressors
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Dewalt D55146 Heavy Duty 412Gallon 200PSI Heavy Duty Hand Carry Compressor with Wheels Logo
196 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
