Question about Samsung WF419AA Front Load Washer / Dryer
Samsung wd-h125N error FE when use dryer function
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
Code FE on samsung dryer??
Hello. The FE error indicates a problem with the incoming AC power. It means the frequency of the power (which is normally 60 Hz) is incorrect. Check the wiring to the dryer, also, is this unit from a foreign country where the power is 50 Hz? The dryer has line filtering built in--make sure the incoming power is correct and that the wiring to the dryer is correctly connected! Get back to me on what you find.Thanks!
Oct 31, 2015 | Samsung Dryers
How do I fix a fe code problem on a Samsung dryer
According to the Samsung website, here is the description of your problem:
FE
  • The FE code indicates a problem with the power source. Loose or incorrect wiring probably exists where the dryer connects to the power cord, or the power cord is the wrong type. If the dryer is hard-wired, it is possibly improperly wired. These kinds of repairs are dangerous for a novice, so contact an electrician or repair center.
Read more : http://www.ehow.com/list_7103891_samsung-dryer-error-codes.html
Dec 31, 2014 | Samsung Dryers
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
I have a Samsung Washer/Dryer (WD-J1255) When trying to complete a dry cycle, "HE2" shows on the screen. There is no such error code in the manual. The machine has been reset and the same happens...
Samsung reports FE is "FAN ERROR".
Samsung replaces the internal die cast fan-heater unit.
If not under warranty, as DIY try unpluuging the unit and removing the top cover. Remove the aluminium die cast "Assy Duct Scroll" which is on the RHS and contains a fan and a heater. Dissasemble by removing screws and remove the clogging by detergent foam and lint. Use vinegar as this dissolves the sludge. Rinse and check that the fan can spin freely. Note that the fan motor or heater could have burned out. However it is likely that a heat sensor that reported FE can caused a shutdown due to over heating.
If cleaning and replacing does not help a new unit may have to be sourced.
Note if exensive corrosion is present the unit will have to be replaced.
Note that use of foaming detergents or too much detergent will cause this problem.
Jul 24, 2008 | Samsung Washing Machines
Samsung washer/dryer code problem
hey, I have the same problem and I am trying to fix it, anybody have any tips?
Apr 05, 2008 | Washing Machines
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Samsung WF419AA Front Load Washer / Dryer Logo
242 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
