Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I have just brought a hotpoint wd 63 and i need an instruction manual
An instruction manual for a hotpoint wd63
    President:
  • 1,294 Answers
Click on your model number (below FIXYA) on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is............
Posted on Jun 14, 2008
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
How do I turn up volumn on the wd-65735 model without remote. it only goes up to 63 and my remote is broken so I need intructions on how to do it manually.
open mitsubishi front door see volumn control push button use +/- if you need new remote part no: Manufacturer Mitsubishi Part Number 290P123010 Description REMOTE
Dec 06, 2009 | Mitsubishi WD-65735 Television
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 23
IT MAY BE WORTH CHECKING HEATER ELEMENT OR THE THEMOSAT
Apr 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD62D
depends how 'proficeint' you are. Its a very fiddley job but can be done easily when you know how!! just have a go!
Sep 21, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
211 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
