Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Neptune Frontloading Washer
I keep getting the code 5d - which is not in my book. My book has d5 which is door is open when washer is running. I have checked, double checked the door and it does lock but still I get the code. So I am thinking 5d is not the same as d5. HELP
  • ronjones630 Nov 15, 2008
    5D code number: we think I had to many clothes in washer. I turned off machine, removed half and then started washers at quick cycle to finish load/
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Posted on Dec 06, 2008
Mine did the same thing it was the little plastic black button that pushes in when u shut the door what sticks broke off i hope i can find a new one
Posted on Jul 12, 2008
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washer will not drain, the door is locked and wont open and d5 keeps coming up on the panel. I unplugged, but nothing will open the door.
if you take the 4 screws out of the dispenser lid you can remove it and find a small green nylon string (looks like weed eater line) pull that and that will release the door. you will need to drain the unit and clear the drain pump as something is likely caught in it
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
Dec 27, 2009 | Maytag Neptune Washer
Error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display showing d5?
d5 - door is open when washer is running.
or the door switch is bad.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune replace door switch
It sounds like a door switch problem, I have seen where they break loose from mount and door pushes switch inside. or the switch my be faulty and showing open all the time. I think u can reach the switch through the top of the washer two screws in the back will allow the top to slide back and up to remove.
Jan 24, 2009 | Maytag MAH8700A Front Load Washer
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG NEPTUNE
Not sure if you solved this one yet..but ...
d5 - Door is open during washing
I have some more codes for a Model # MAH6700AW if you need them.
Nov 04, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
597 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
