Question about Uniden Bearcat Pro PC68LTW 40-Channels Base CB Radio
I won't transmit or receive and it doen't key up. I hooked up a spare cobra 25 and it worked fine, but I like Uniden better.
    Genius:
  • 1,274 Answers
Hi,my name is John. Welcome to FixYa. First try a different mic, one thats wired for it, if I remember the cobra mic will work on it. If that does not do it, let me know, might be internal that I also can help you with. Good luck and thanks for choosing FixYa....John
Posted on Nov 04, 2010
Testimonial: "very helpful in trying to help me"
Static in my cobra ultra 3.
The easiest way to check this is to hook an SWR meter to the antenna to see if the cables are ok. If the SWR is low then it would show no problems in the transmit and therefore the receive would be good.
Mar 03, 2014 | Cobra 25 LTD 40-Channels Base CB Radio
I I have an old Uniden PC 55 CB radio that I picked up at a junk store. After some tinkering, it seems to receive just fine (a little scratchy) but it won't transmit. A friend replaced the connector on the...
The final amplifier circuit goes out on these often. It controls transmit power. They transmit, they light up, they emit about .25 watts or less. IMHO, you are done. They simply are not worth anything and there are no parts available for that repair.
May 28, 2017 | Uniden Radio Communications
Meter don't work
Hook radio to a dummy load with a watt meter in line---if no actual power being transmitted radio will not go to cal or show transmit power.
May 19, 2012 | Cobra 29 LTD CB Radio
Cobra 25 LTD classic no transmit or receive.I have checked the mic and finals and they check ok. I beleive it might be somewhere in the VCO.Any help
With the radio on, and the case off. Rub your finger gently across the contacts of the audio chip on the trace side of the board. If you hear noise from the speaker it is good. if you don't hear anything(make sure the speaker is hooked up) then the audio chip is bad. You need to change it.
Jan 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 ltd wx classic
the mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio
hope this helps.................good luck!
Dec 18, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
I have a cobra 29 and all it will do is light up. It will not receive nor will it transmit. What might be the problem?
the easiest thing to check first is the mic..........if the mic is broken cobras wont receive or transmit
hope this helps.......good luck!
Dec 05, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden Bearcat Pro PC68LTW 40-Channels Base CB Radio Logo
198 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
