Question about Sewing Machines
White 2037 Bobbin Filling
I can't find my manual and haven't filled a bobbin for a few months. Do I wrap the thread around a certain way? I know I put the bobbin on the spindle on the top and click it over to the right, but thread keeps getting wrapped around the spindle holding my spool of thread just under it!
Thanks
    Problem Solver:
  • 26 Answers
Turn your thread 3 turns to the right, clockwise,
then pass theend of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Posted on Jun 14, 2008
Not catching to wind the bobbin
you have to hold the loose end for a few seconds .
Mar 20, 2016 | Sewing Machines
I owen a Creative Touch Fashion Machine Model 1030. I tried to fill the bobbin and the thread is filling under the bobbin instead of inside the bobbin. Had it fix in late 2009 and it came back with this...
I've had that problem before, I wrap several loops on the bobbin it's self & as I start to wind I make sure the thread from the spool is pulled tight from the spool to the bobbin,,& that usually takes care of the problem
Aug 01, 2011 | Singer Sewing Machines
I am having problems with my bobbin. Every time I load it and start to sew it gets jammed and the needle stops. There is a mess of thread around the bobbin.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | White Sewing 2037 Mechanical Sewing...
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
When winding the bobbin, the thread keeps wrapping around the bottom of the bobbin post
Make sure the bobbin is pushed all the way onto the post and that the thread is running through the tensioner on top of the machine above the needle area.
Jan 16, 2010 | Bernina Sewing Machines
Cannot thread bobbin
If I remember correctly this machine has a little arm in the bobbin case area. You will need to open the slide plate, move that arm towards the middle of the bobbin. Thread your machine as normal, take the thread going through the needle eye and wrap it around the thumb screw a couple times, then start "sewing" your bobbin should begin filling, once started, you can release the thread wrapped around the thumbscrew. Once filled, you simply close the slide plate and that moves the arm back into place and start sewing.
Dec 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
PLEASE GIVE ME THE PRODUCT # FOR BOBBINS FOR WHITE MACHINE MODEL # 2037. THANK YOU
Rebecca, I don't know if you ever received a solution, but after my experience with my White 2038, I would advise you to do exactly what you said. "Throw it out". I've struggled for a week with a new machine, found parts missing after opening the box and generally feel ripped off. I am throwing mine out! I purchased a Singer yesterday and it is sewing beautifully with no problems.
Good luck.
Jul 03, 2008 | White Sewing 2037 Mechanical Sewing...
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
191 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
