Question about Panasonic PV-DV103 Mini DV Digital Camcorder
Check rec! tab how do i do that anyways? - Panasonic PV-DV103 Mini DV Digital Camcorder
    Genius:
  • 1,177 Answers
Mini DV tapes have a little switch thing on them that write protects the tape if it is set in one position, or allows the tape to be written to if set in the other position.
Posted on Nov 04, 2010
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
Check rec tab
A nice easy one. Eject your tape and look for the record lock on the cassette. It's usually a small plastic red tab which you slide to one side. The record will then work.
It's put there to stop you mistakingly record over the top of something you want to keep. Just make sure it's nor something you want to keep before recording over it :-)
Apr 10, 2010 | Panasonic Palmcorder PV-DV203 Mini DV...
Casio EX-S5 camera, how do you set timer so I can be in pix
In the REC mode, press [MENU], select the REC tab, then select "Self-timer."
Dec 20, 2009 | Casio Exilim EX-S5 Digital Camera
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Problem with Sony DSR 1500A won't record error flashes "Rec Inhib
dear,
the rec inhbit cable is faulty in this case ...
u need to replace that (holder assy,MIC.)
Regards
Jun 14, 2009 | Sony DSR-1500 Mini DV VCR
Can not get it to record. it says check rec tab
Hi there.
The REC tab is on the cassette itself, take it out and make sure the tab is there.
Good luck and thanks for using FixYa!!
May 07, 2009 | Panasonic NV-GS25 Mini DV Digital...
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Can't find my recording
There are disk recovery services listed online, but they will probably say no. Only way to find out is to call them.
Jun 25, 2008 | iRiver iFP-895 MP3 Player
Rec Inhibit Light remains ON
The easiest way I know to fix the problem is just play tapes. Sounds like a bad switch contacts. clean the contacts or replace the switch. I don't know of any shortcuts. Sorry
Apr 16, 2008 | Sony PVW-2800 VCR
Panasonic PV-DV103 Mini DV Digital Camcorder Logo
79 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
