Back to:
Tags:
Lexmark X4270 All-In-One InkJet Printer
Won't Print
posted by vicki56 on Jun 14, 2008
I put in a new ink cartridge and now it won't print is there a something else I should be doing?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 16, 2008
Not Rated (0)
lilacgerry
Rank:Wiz Wiz
Rating: 78%, 401 votes
Hello, most printers need to be told there is a new cartridge. This will be in your printer menu from the printer icon in your taskbar or wherever you have your printer help files will tell you how to do this also. If this is a refilled cartridge it also would not hurt to clean the printheads and do a clean with printers own program as well, and also a test page to make sure it is printing. Post back if no solution. xxx
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Won't Print:
I don't want to Accept this solution
Can you Help with these Printers problems?
I am setting up my lexmark 4270 printer after moving, all...
pressed black start button when a fax was coming in no...
i have a lexmark4270 and i can send faxes but when a fax...
i just want to make my own back ground........
followed your advice problem fixed thankyou......lesley
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
