Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Will not bootup.fans com on and thats it. - Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
  • Intel Master
  • 27,725 Answers
Test the leads that are attached or replace the leads that are attached to your hard drive including electrical extensions the one from your motherboard that attach to the hard drive one bad/faulty lead can cause a computer lots of problems
hope this helps
Posted on Nov 04, 2010
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Fan runs constantly.
OK generally the Fan is controlled via the CPU, settings can often be adjusted in the system BIOS, that is accessed before bootup by pressing a key, often the DEL key straight after switch on.
There is a program called speedfan, this is an excellent free program that allows controll of ya fans it has extensive help and is easy to install and use.
www.almico.com/speedfan.php
I hope this helps you.
Jan 19, 2010 | HP Compaq Presario SR2150NX PC Desktop
The CPU Fan stop after the pc boots
The fan will only run when needed to cool the computer. Fans normally run at full speed during bootup, but turn to low speed or off after bootup if not needed. Is your computer running hot enough that the fan SHOULD be running?
Sep 07, 2009 | Acer TravelMate 290 Notebook
Same problem as others cited. Fans race and no bootup
Please remove C-mos battery from *********** board & reinsert it,Before it power down the system. After that in c-mos setup selsect Default load & restart the System.
Jun 28, 2009 | E-Machines eMachines Desktop PC
I have to hit the f1 key to continue the bootup process. Then I get a defective fan error message, but the fan is running, becasue I can hear it.
there may be more than one fan-- there also is a setting in the BIOS to disable the fan warning if you are SURE that the fan it is monitoring is working correctly.
Jun 24, 2009 | Gateway M350 Notebook
On bootup checks, stops at 02FC Main and second fans failed. Black screen with bootup messages. ?Has the MA7 even got two fans? How to correct.
Sounds like you may have a virus or trojan of some sort. They are hard to get rid of but try downloading avg 8.0 it's free and picks up most trojans and viruses. If you get a black screen with boot message just hit control alt delete together and your pc should bypass this problem and allow you in. If avg doesn't pick up trojan or virus it maybe a software failure but it will usually tell you whats missing and if pc was working fine and just started this it is most likely a virus or trojan
Jul 26, 2008 | Gateway Computers & Internet
Bootup problem
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
81
Mar 08, 2008 | Intel D845GVSR Motherboard
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
