Question about Kenmore Refrigerators
Kenmore refrigerator model # 106.57362700 ice dispenser gate located in freezer door will not close. I have located the problem, a broken plastic part holding the gate hinge. How do I get inside the door panel to remove the broken part. I am afraid to pry too hard. Is there a specific point on the dispenser panel from which to start? Any advice will be appreciated!
watugot
  • 290 Answers
SOURCE: Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Posted on Oct 20, 2007
  • 145 Answers
SOURCE: Whirlpool refrigerator ice dispenser
The front cover is snapped on. There should be two slots in the bottom of the cover. Put a wide screw driver in the slots one at a time and pry out. It snaps off very hard.
Posted on Apr 24, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
aasc
  • 1606 Answers
SOURCE: Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Posted on Oct 10, 2009
Ice Maker not dispensing, auger not running
Hi Zack, this is AP!
I understand you are experiencing trouble with your Frigidaire refrigerator not dispensing ice from the dispenser on model#PLHS267ZA. First, check to see that both doors are closed. The dispenser will not operate if the freezer door is not closed to make the safety switch located where the door meets the outer wall of the freezer. Close the door and make sure nothing is blocking the door keeping it from closing. Another troubleshooting tip is to disconnect the power to your refrigerator for 5 minutes, then reconnect and try to dispense ice. If you are still experiencing the same problem there could be a problem with the motor releasing the ice. If your appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information helps to some degree.
Best of Luck,
Mar 29, 2014 | Frigidaire PLHS267ZA Side by Side...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
My ice maker is making snow in the dispenser area---What can I do to resolve this?
I would look at the dispenser door to be the issue not the ice maker. This door if not closed will allow warm air to enter the freezer and create frost.
You would look into the dispenser door and clear the ice out, use a flashlight, open and close the dispenser door, if you see light after this. replace the dispenser door and or bar, spring, or other related part to the dispenser.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 12, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
MY FRIGIDARE MODEL FRS23ZTJ IS NOT WORKING RIGHT. THE REFRIGERATOR IS NOT COOLING. THE FREEZER SEEMS FINE. WHAT DO I DO NOW?
check the damper door located between the freezer and refrige compartments,it may be iced up in the closed position and can't let cold air in from the freezer,it may be covered behind a plastic cover or diverter,you may feel some cold air in this area moving if its open part way,if its iced up,use a hair dryer and defrost it then adjust the cold control in the refrige and see if the damper door opens and closes with adjustment of this control
Mar 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Dec 01, 2008 | Refrigerators
Refrigerators Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bailey's...
Bailey's...
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
