Question about Lexmark Office Equipment & Supplies
I have a lexmark X2470 I just put in a new ink cartridge and I can't get the printer to work?
  • 2,035 Answers
Did you remove the tape under the cartridges and try to print a test page if this does not work you need to clean and wick and check...........Click on this link:
Good luck............
Posted on Jun 14, 2008
Replace ink cartridge
Perhaps the Lexmark X2470 User's Guide will be able to help you. Click on this link to download Scroll to page 42 for the instructions on how to install/replace the ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridge. Close the cover. Plug the printer back to power source. Thanks.
Oct 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
Printer Lexmark x2470 doesnt recognize the cartridge anymore.
Good day Sir, I suggest use the Solution Center. to open click start - programs or all programs - Lexmark Solution Center. find the maintenance tab. Maintenance tab help you install print cartridge and troubleshoot other ink problems.
have a nice day.
Jul 29, 2010 | Lexmark X2470 All-In-One InkJet Printer
LEXMARK X2470 wont print in yellow with new cartridge,
try to clean the base of cartridge and clean surface of cartrage and the base where it fits in to clean it too.
Jul 23, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
How do i change the ink on my lexmark x2470
Changing a print cartridge
Removing a used print cartridge
Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the lever to raise the cartridge lid.
4 Remove the used print cartridge.
Good luck
Oct 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark All-in-One Alignment Problem
-take out your cartridges and put it back in again after 5 minutes.
-print an alignment page and you have to scan the alignment page that you printed
-try to print
Apr 07, 2009 | Lexmark X2470 All-In-One InkJet Printer
Will cartridge for x2480 work in 2400 series
What is the number on the cartridge you removed?
Jan 18, 2009 | Lexmark X2470 All-In-One InkJet Printer
Unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
