Question about LG KU990 Viewty
Quick Menu Okay you get the normal menu at the bottom of the screen right, but for some reason there is this quick menu right in the middle of the screen and I can't for the life of me seem to be able to get rid of it, I know its not just how it spose to be because when i first got the phone it wasn't like that it was just a plain screen with the default wallpaper but now random all of a sudden this other menu appears its damn annoying.. I know this isn't a technical diffcult but yeh HELP! please
The solution works
Posted on Jul 21, 2008
Hi. If the quickmenu has 'New messeges', 'Bluetooth', 'Calendar' etc on it then I think I know what your'e talking about.
Under the quickmenu, there should be some kind of animated arrows on either side. If you touch them the menu should disappear.
If you can't see the arrows then just touch the empty space under the quick menu and the arrows should appear there.
Hope it works
Posted on Jun 15, 2008
How to Open the Control Panel?
Click the bottom-left Start button to open the Start Menu, type control panel in the search box and select Control Panel in the results. Way 2: Access Control Panel from the Quick Access Menu. Press Windows+X or right-tap the lower-left corner to open the Quick Access Menu, and then choose Control Panel in it
Oct 18, 2016 | Computers & Internet
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
How do i turn off the text to speech feature? It has been accidentally turn ed on 3 times. can't get to settings to turn off.
Step 1
Swipe the Status bar at the top of the screen towards the bottom of the screen to display the Quick Settings menu, and then tap "More." To open the Quick Settings menu in Explore by Touch mode, use two fingers to swipe down the Status bar.
Step 2
Tap "Accessibility" to view all settings related to accessibility. Locate the Text-to-Speech and Voice Guide options in the menu.
Step 3
Turn off the "Text-to-Speech" and "Voice Guide" options to disable the voice capabilities of your Kindle Fire HD.
Jul 29, 2015 | Amazon Kindle Fire HD 8.9"
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
I only have a little screen showing
right click on the desktop/normal home screen click properties at the bottom in this menu you can change the settings of your resolution to make your screen the right size. you will have the option to change it back within 15 seconds if its not correct or prompted to click okay to keep the setting you have chosen to use
Jan 11, 2011 | Computers & Internet
Put in password 3 times then laptop locked up. All I get is a blank screen with the cursor in the top left hand side.
try starting it in safe mode, right after you turn it on you will se option like esc, f1 and f10 at the bottom of the screen, press the f8 key and a menu will display, use arrow keys to go down to safe mode option then press enter, do it quick, you only have 25 seconds to do it before computer starts normally, you wont see the f8 option but you have to press it, if it doesn't work, try keeping it pressed till menu shows...
Oct 05, 2010 | Computers & Internet
How do i use the webcam
Followfollowing steps to connect use web camera to capture yourself.
Firstof all Click the "Start" button. Click on "All Programs"and then click "Quick Play." The Quick Play main menu will appear.
Then Clickthe "Music, Video, Pictures" application icon. This button looks likea headset, film and photos. The "Music Video Pictures" page willappear. Double-click "HP Webcam" from the "Source" list.The webcam application will open. Double-click the webcam screen and it willopen to full page view. Press the "Esc" key on the keyboard torestore the webcam screen to smaller view. Click the "Record" buttonat the bottom of the screen to record video using your webcam.
Clickthe camera icon at the bottom of the screen to take a snapshot. Find yourpictures in a folder named "My Snapshots."
Dec 16, 2009 | Acer Aspire 5335-2257 Notebook
Cant kick out the quick menu
****, I've got the same thing, bloody annyoing..
Sep 06, 2009 | LG KU990 Viewty
How do I delete my quick text entries
Go to menu
Then Messaging
You should see setting on the bottom of the screen, go there.
Then go to All Messages
Then go to Quick Text
Once inside there you should see the option to erase any and all quick text. Also, you should see where you can add new or your own quick text.
At least that's how it is on a few of our phones.
Otherwise, get to Quick Text anyway you can, and see if you can delete it once inside there.
Sep 03, 2009 | LG VX9400 Cellular Phone
Language
Okay well for a start when your on your home screen select the middle button so you are at the menu. Then go to the little picture of two cogs in the bottom right hand corner and press the middle button. There should be numbers on the sides of all options , select the number 6 by simply pressing the number 6 on your keypad. Now you should be on the language menu. These should also be numbered. Select number 2 by clicking 2 on your keypad. The language on your KF 310 should now be in English mode. :)
Aug 17, 2009 | LG KF310 Cellular Phone
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
