Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loader
I have a problem the f11 code appears can you help
  • 1 more comment
  • Anonymous Jun 17, 2008
    F11 error responded to reset COO that was posted but problem has reoccured. dL code comes as well as F11.
  • kcgingrich Aug 29, 2008
    f11 code on HE3t
  • Rodney Gene Oct 11, 2008
    I am having problems with F11 code and a loud buzzing noise and the washer does nothing with my clothes locked inside soaking in dirty water. I have pushed the pause button and reset the f11 code and then had to push the drain and spin button to get it to drain and spin and eventually unlock the door. Now it wont even do that. Is there anyone out there that has had a similar problem? If so what did you need to replace to fix it. I have taken many a washer apart and if I knew what to replace I can fix it myself. Thanks in advance
    Rodney
  • 246 Answers
F11 is an error code that appears when the main control board up top is not communicating with the motor control board on the bottom. Unfortuneately, there is not a test for customer to do to test where the problem lies. The only thing a customer can do is check the connector going between the two boards to see if the connection has come loose. First, drop the lower front panel (3 #20 torx screws along the bottom) On the left hand side you will see some blue, pink and green wires going to a white plastic looking box. This is your motor control board. Unplug and plug back in the connection making sure to not get the wires turned around as it can plug into the board both ways. Next, take the top off the machine. (3 #20 torx screws on the top rear of the machine) Again, unplug then plug back in the 3 blue wire connector on the left hand side of your main control board (white box all of the way at the top in the center). If the problem still doesn't clear, you will need to replace one of the two boards. Again, I have not heard of a way to test the boards themselves. The problem usually comes from the board on the top.
Posted on Jun 16, 2008
We've had the same F11 error code for the past year. Our problem appears to be a sticky relay or loose connection that has been routinely addressed by pressing the pause button to clear the F11code, then pressing the start button, and most importantly, then sharply hitting the top panel near the left rear part of washer with a heavy metal bolt (or hammer). Stingy as I am, this indeed does work.
Posted on Jul 10, 2008
Thanks for the tip, I took the motor control unit MCU out and found a burnt chip. The Repair Clinic had the part for $188
Posted on Jul 01, 2008
Machine is starting to show error codes, ie Dlr door lock and code #11
Do you mean F11 code? The Problem may be a communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU). You need to check the connections between them and verify that nothing is loose. I don't have a service manual for this type of front loader but if you have access to one it will give you a protocol to follow to verify which part is the most likely to be causing the failure.
Feb 10, 2015 | Kenmore Elite 45986 Front Load Washer
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
I have an E4 front loader it is flashing F11 what does that mean?
If you're handy, there's a guy on Ebay who seems to specialize in the F11 problem. Here's the web address:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
I know nothing about him, but he has great feedback.
Jan 16, 2011 | Kenmore Washing Machines
Why does my kenmore front loader washer get the f 11 code and stop what can I do?
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
TROULBING SHOOTING FOR A FRONT LOADER KENMNORE ELITE 31T
check the screans on your water valves lf is a long fill Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
• Check Wire Harness thats the f11 error now if you pull the top off the washer you will find atech sheet in an envelope with troubleshotting procedures
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
181 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
