Will not drain or spin, wash cycle is fine - Washing Machines
  • Jason Kennidy
    Jason Kennidy Nov 04, 2010
    What brand is this?
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • Thanks and good luck.
    Posted on Nov 04, 2010
    Miele washing machine wont spin or drain
    clean your filter first then check there is nothing in the pump area
    Jan 22, 2014 | Miele Washing Machines
    Washer will not spin in wash cycle
    I have a Kenmore washer that will not spin or drain.
    May 31, 2010 | GE WBSR3140DW Top Load Washer
    Does not drain and spin
    It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
    Sep 17, 2009 | Malber WD1000 Front Load Washer/Dryer
    My washer will not spin in any cycles
    i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
    Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
    Washer wont spin or drain
    did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
    Feb 07, 2009 | Frigidaire Washing Machines
    Whirlpool washing machine not draining.
    Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
    Oct 07, 2008 | Washing Machines
    Washer will not pass wash cycle...Will not Drain
    Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
    Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
    Washing Machines Logo
    47 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
