Question about HP Pavilion dv1000 Notebook
No power - no boot
After following the HP troubleshooting directions, I was able to get my laptop to boot up. The computer worked over an hour then suddenly shut off. I have since been unable to get the computer to boot up. I have reseated the ram, changed the ac adapter, nothing. Any suggestions?
Thanks for your input.
  • 1 more comment
  • wwjdjata Jul 05, 2008
    I tried your suggestion but unfortunately this did not solve the problem, so I must assume it is the motherboard failure as you mentioned.
    Thanks for your help!
  • Anonymous Oct 06, 2008
    twice now my DV1000 has randomly shutdown with no signs of power. I have tried using two seperate power supplies and also with battery installed and without it installed. Eventually I was able to get the laptop to return to life and then it works normally. I am not sure what is causing the sudden shutdown but it is worrysome. I'll never by another HP product after my experience with this laptop and also with the HP all in one printer I have.
  • 80orenda May 11, 2010
    Hi there my pavilion dv 1000 pc Notebook caught a serious virus and is not able to boot.......whenever i hit the power botton the screen begins to start up but stays black. What should be my next step if i'm not able to pay to get it fix right it possible to get online help for this.......thank you very much Tony
  • 119 Answers
No power no boot can be indicative of a motherboard failure or could also be the memory. try removing all the memories, hard drive, the optical drives and all external devices connected to your computer. if you get to hear a beeping sound .. your in luck your motherboard is alive and just need to isolate which among the remaining pieces is causing the no power.
Posted on Jun 19, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
How to wipe out HP mini hard drive
To restore your hard drive using Disaster Recovery, follow the steps below.
1. Shut down and power off your HP Mini if it is not already powered off.
2. Connect an external USB optical drive to the HP Mini.
3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc.
4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer.
5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.
Mar 28, 2010 | HP Mini 1000 Netbook
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Computer keeps returming to the startup page every 15-20 seconds
Change the boot order to have the CD drive the first boot device.
Mar 18, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
No power - no boot
You need to State some of your Symptoms... Like what you are seeing when attempting to boot.... is the screen just black?? do you see the BIOS POST... does it go to loading windows... do you see any lights turn on after hitting the power on button.?.. do any fans spin?? More Info.....
You might want to check the Heatsing Fins and the fan(s) they're probably clogged and your laptop is getting overheated and causing it to shut down... Unless it doesnt power on at all.. no lights no nothing... then it's most likely your motherboard..
Jul 07, 2008 | HP Pavilion dv6000z Notebook
Pavillion DV1000 will not boot
may be two things 1. your powersupply unit is gone or 2. your motherboard
Jun 11, 2008 | Computers & Internet
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
Thanks and Regard
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv1000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
