Question about Frigidaire Electric Dryer
Dryer still working but air is not hot- model # LEQ642DSO
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101 ..
Posted on Nov 04, 2010
Electric lift stopped 2/3 way up. There was also a burning smell. Won't work at all. Is there a manual overide?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is no manual override on your dryer. Which is a good thing.
You do not want to run your dryer at this point.
The burning smell is burning lint. Your dryer is plugged up with lint. This is a dangerous situation. You could burn down your home.
Your dryer will not run because the dryer fan will shut down if the air flow is obstructed.
You have a hot air exhaust manifold where the hot air goes into a round bottom inlet up to a expanded hot air distribution headed into the dryer. This is usually plugged up.
This may also have caused the fuse to blow, a operating switch or high temperature limit switch to fail.
Go into the following website and put in your model number. You will get diagrams and component part numbers. Your model number is located on a label either on the face of the dryer when you open the door or on the side of the door.
Water Filters Lawn Garden Appliance Parts
Mar 10, 2016 | Dryers
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
Maytag dryer stopped heating
Hello Daniel;
You have not provided a model number, so I do not know if you have an electric dryer or a gas dryer. Your model number should be on a label on the unit after you open the door.
In general:
1.) Bad Igniter (Gas Dryers) - You may have a bad igniter. Although it may glow red it may be too week to open your gas valve. This is about a $35.00 USD component.
2.) High Temperature Thermal Switch - This component could be bad. As soon as it senses any temperature it will shut you down.
Depending on your unit it is generally located on your hot air distribution manifold. This is about a $12.00 USD component
3.) Poor Air Flow - You may be just plugged up with lint in your hot air distribution manifold and duct work.
Sorry, I can not tell you where your problem area is, but I have no model number to go on.
Jan 23, 2015 | Maytag Dryers
My gas clothes dryer is working,but it is not blowing hot air
The thermostat or thermal fuse could be blown. Usually happens when lint buildup blocks the exhaust exit & the heat stays inside the machine. So to prevent a fire, the thermal fuse or thermostat blows. You would have to enter your model # on google to find links to parts breakdown.
Sep 13, 2014 | Maytag Dryers
LEQ642DSO
Hi Friend, I am happy to assist you!
I understand you have a Frigidaire dryer, LEQ642DS0; however, what exactly is your concern. Are you seeking an Owner's Guide or is your dryer experiencing an issue? With this information I can assist you better in pinpointing the problem Thank you! - Z
Jul 15, 2014 | Frigidaire Dryers
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
I ust replaced belt/tensioner/front upper and lower felt and rear bearing and clean vent out still have a vibration/ humming noise could noise come from exhaust blower ?
That is exactly what it is. Frigidaire dryers are known for the bearing wearing down and causing the vibration. Here is the new blower you need.
Don't forget to move the thermostat over from the old blower to the new one!
Oct 19, 2012 | Frigidaire Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore Model 110.747424000
check your exaust blower wheel...its defective
Dec 12, 2008 | Kenmore 72802 Gas Dryer
Frigidaire  Electric Dryer Logo
115 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
