Question about Sony Ericsson Walkman W810i Cellular Phone
Side color red light
The phone isnt starting at all.
There is only a red color light on the side which is glowing.
Please help me..
thanks for the support
    President:
  • 1,944 Answers
Try taking and leaving the battery out overnight. then replace ands try to turn on. If this doesn't hel, try flashing the software on your phone.
Posted on Jun 14, 2008
Freezer problem.....Frozen coils and glowing red under the coils what is the part called and how expensive
That red glow is the defrost heater. Its supposed to do that.
It should have defrosted and kicked back into cooling.
Here is some extra info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Jul 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
Hi i have a york diamond heater in my attic. I went up in the attic and revomed the grill and the four burners are not coming on. it clicks and u smeal gas but it will shut off. the little blower motor...
If your furnace uses an electrical glow element to light the pilot light, the Glow Element will need to be replaced. Glow Elements are general used on 90+ High Efficiency Gas Furnaces.
If it uses a standing pilot light rather than the Electrical Glow Element, you need to manually relight the pilot. Since I can't see your furnace, you will need to locate and read your Owners Manual on how to do this or look in the side or inside the pilot light compartment for instructions on how to light it.
Be sure you have stick match or a butane grill lighter with you before you try to light it.
If it's a manual pilot ... if after lighting it, it doesn't hold when turned to the ON position, more thank likely you'll need to have the Thermocouple replaced.
And above all, BE CAREFUL. If you don't feel comfortable lighting a gas furnace, call a professional.
Feb 07, 2011 | Heating & Cooling
My Kodak ESP-3 printer is not printing. There is a red light flashing and I do not know what it means. it is under the on off button. It just shoots out blank paper Kathleen
Clean the printhead, then print a test page.
  1. On the control panel, press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes. The On/Off light continues to flash during the cleaning procedure.
  2. When the On/Off light glows steady, press and hold Quantity + Cancel simultaneously until the On/Off light flashes, then wait for the test page to print.
  3. Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  4. Is it still printing blank?
  5. Please :Call Kodak to Report Code BP03
United States Telephone Support spacer.gif spacer.gif All-in-One Printer Phone Support
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
The expected wait time for phone support is 15 minutes
  1. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
Dec 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When the glow plug light comes on the truck fires up every time, when u turn the key on and the light isnt on it just makes a clicking noise at the relay by the passenger side battery
The old 7.3 diesel motors are great when they run, their biggest fault is in the glow plug control relay (passenger side fender well), wiring for the glow plugs (harness) and the glow plugs themselves. If you are sure of wiring harness and the plugs, the relay would be the place to start. Hope this helps, and if you have any more questions please let me know.
Thanks,
Joey
Sep 04, 2010 | 1985 Ford F350
F250 Diesel will not start cold . Has power to glow plugs for short time ,but will not start 1986 modle.
Hello philkatkiele: My name is Roger and I will help you. First thing you need to check is the glow plugs. They will need tested individually. Un plug all 8 glow plugs. Take a test light and hook end to the positive battery cable. Touch opposite end of test light to the terminal end of the glow plug. The test light should light. Touch all 8 glow plugs. Ant that do not light are bad and will need replaced. If glow plugs are burnt out then the controller will flash wait light to early or very fast. The wait light should be on for approximately 10 seconds.If al glow plugs check ok then I would suspect the glow plug controller as the problem. Also if the temperature out side is below 40 degrees the truck should be plugged in. This will help to make the engine start easier. Should you need further help please just ask.Please rate the answer as this way I know it was helpful. Thank You for using Fix Ya. Roger
Feb 15, 2010 | 1986 Ford F 250
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
FOUR LIGHT GLOWING WHEN EVER HEARING MP3,I WANT TO STOP IN ALFATEL H1 MOBILE
to stop the four lights, goto settings --> phone setup --> set Run Light. select the option off.
May 28, 2009 | Handmark Software MobileLists (950142) for...
Why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Nov 11, 2008 | Cell Phones
Side light Red Color
Try taking and leaving the battery out overnight. Then, replace and try to turn on. If this doesn't help, try flashing your phone's software.
Jun 14, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
82 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
