Question about Canon ZR90 Mini DV Digital Camcorder
Only blue screen, no functions work. Have to remove battery to shut off.
When I turn the power on, I hear the ding and the screen turns blue and the word Canon appears. No functions work. I can't take pictures or videos. I received this camera in 2005. It is probably a 2004 model. Also I cannot turn the camera off without removing the battery.
  • jammin jerry Jun 14, 2008
    I just tried plugging it in to the outlet and it worked. I also put the original battery in and it worked. I thought the battery that is in it was charged up but maybe it isn't. I am charging it now so in the morning I will know if it is that battery or not.
    I really appreciate your help.
    Thanks and God bless,
    Jerry
  • Tim Babcock
    Tim Babcock May 11, 2010
    How does it work when it is plugged into an electrical outlet?
  • Canon Master
  • 2,794 Answers
Your welcome.
Posted on Jun 14, 2008
Model Rs265TDRS. Why is it indicating 0f for both the freezer and the fridge?
That is the cooling off function. to turn it off in own press power freeze and freezer temperature buttons together for 3 seconds until a ding sounds. To do this again to turn it back on press the same buttons together simultaneously for 3 seconds until you hear the ding sound
Nov 27, 2015 | Samsung Refrigerators
Changed battery terminals and now dinging wont stop unless warning light fuse removed
It sounds like it thinks the key is still in it all the time. Try turning the key forward to the on position, but not running, so the dinging stops. disconnect the battery. Remove the key completely and reconnect the battery.
Oct 21, 2014 | 2005 Dodge Caravan
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
It wont turn back on.... turned it off, shut it, now the screen is blank and its making some kind of dinging sound.
open cover/screen remove the battery, put in ac charger, press power button to turn on when it does start beeping press and hold down power button till it restarts, should do the trick if not you may have a bad cpu that is the prosseor has fried. Goodluck!
Jul 17, 2009 | Acer Aspire 5315 Notebook
Phone shut off
Have you tried removing and replacing the battery pack? Or removing the battery and plugging it in to the charger? If neither works, try holding down the Power button to get it to start back up.
Jan 06, 2009 | T-Mobile Wing™ Smartphone
1996 BUICK REGAL DINGING NOISE
the dinging is from having the turn signal on to long it s a warning I know that sounds strange, mine did the same thing happen to me i made a turn but the turn signal didnt shut off couple mins. later i hear ding ding ding looked at dash turn signal was on shut it off it quit dinging. hope this helps
Dec 08, 2008 | 1996 Buick Regal Olympic Gold
Toshiba Satellite M45 S331 PSM40U-01R001 will not power on
No.. the problem has nothing to do with your battery....
Yes Quite Possibly the motherboard is fried...
Nov 18, 2008 | Toshiba Satellite M45-S331 Notebook
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
Canon ZR90 Mini DV Digital Camcorder Logo
169 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
