Question about Jackson 10A Free-standing Dishwasher
We have and older Jackson model 10 AB at church, used 10 to 20 times per year. The pump motor quit this summer and was replaced by a local appliance service company. About $700 job. Upon using it recently, the first time since the new pump was installed, the RINSE cycle seems very anemic, that is, low volume and low spin rate. The dishes were not completely rinsed. Temperature was correct, 185 degrees. The service person came back to look with no improvement and now the Heaters will not come on either. The motor runs fine, wash cycle is fine, fuses in wall box are fine, other switches are fine, heater switch will not light the red light and heater will not come on. We believe the actual switch to be fine since it shows continuity with switch in 'on" and no continuity in "off."
    President:
  • 1,891 Answers
Sounds like a wiring problem but it is controled by a thermo to make sure you get to the proper tempt . so ck the connections and mke sure the thermo is good . . and the element is good . ..hope this helps mm .. ps run the dishwasher at least several times a month as sitting to long is not good for it . ( once a week would be even better ..) mm
Posted on Nov 05, 2010
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Feb 04, 2017 | Riccar Vacuums
New polygroup 2000 gph pump is loud
firstly, don't be so certain that doubling your pumping capacity isn't damaging other parts of your pool system. Excessive flow reduces filter efficiency, can cause hyper chlorination, and cause faster degradation of the plumbing and pool surfaces.
a noisy pump typically indicates poor lubrication on bearings and bushings in the pump assembly, or misalignment of those parts. Things like this happen.
Either replace the pump (and i recommend going back to the original design specs) or rebuild it, using new bushings / bearings, high quality lubrication, and be certain that the drive shaft is perfectly straight, and that the bushings allow it to spin freely.
Jul 04, 2014 | summer escapes Polygroup Quick Set...
New pool pump motor is rattling
This really sounds like a motor going out. I would take it to a motor shop and have them check the bearings.
US Parts Center
Apr 07, 2014 | AO Smith Pool & Spa
I have a Paradise II, had it installed on 10/06 around March of this year one of the motors for the jets quit. We shut the spa down every summer so we did not have someone come out and look at it. Once we...
If this is under warranty call the manufacturer. If it was purchased at a big chain store like cost-co call them. It is very common for hot tubs that are shut down most of the year to have these problems. The motor shaft seals need to stay wet, but when shut down they are dry. When they go dry they shrink, causing leaks, which will in turn let water leak into the motor housing, which will in turn seize the motor bearings. It is much better once you have it up and running to run it year round, and when not in use, turn down the temperature as well as switching the controls over to "economy" Every spa made in the last 10 years has this setting. It will cost $.25 /day to run like this (about) which is way cheaper than service labor and parts. If you have a good spa tech. he should be able to replace the bearings for $35 each plus one hour labor per pump. If you have a bad spa tech. just pay to replace the pumps or do it yourself.
Oct 08, 2010 | Qca Spas Paradise Hot Tub
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
Need replacement grids for older waffle bakers
Hi Kriss, I would go to Amzone and put in waffle iron. You can buy new ones for the price it would cost for the replacement.
Kind regards
David
Nov 29, 2017 | Toastmaster Kitchen Appliances - Others
Refrigerator model 309YBT quit working on Friday
Good day,
You did not say if it was running or not.
If not running at all, then it may be the cold control, (thermostat) that has failed. You can remove it, jump the 2 wires going to it, and see if it runs and cools.
If so, you may be able to contact your local appliance parts house for a replacement.
However, if running and not cooling, then 2 options.
1. If under 5 years, sealed system should be under warrant. Call your selling dealer for details.'
2. If over 5 years, not price effective.
Nov 16, 2009 | Avanti 309YBT Compact Top Freezer...
This dishwasher is older than most living people in this business. It works great except it is a 208 three phase unit. It is in St.Peter's church in New York Mills, MN. We bought it used during our remodel...
Your AM9 is too old to get new parts from Hobart.
Why does the inverter need to run when the machine is not in use? There must be a breaker to turn it off.
If you decide to replace it, any AM series will fit your tables. Don't buy anything older than AM14.
Apr 05, 2009 | Hobart AM14-253 Free-standing Dishwasher
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Dishwashers Logo
90 people viewed this question
Top Jackson Dishwashers Experts
gbob59
ray gallant
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
