1986 Volkswagen Wagon Camper Logo
Posted on Jun 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont start 1985 VW camper wont start unless I put a little gas in the throttle body??? What could be the problem?
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Jun 22, 2008
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
59335
Points
122
No fuel issue. check fuse for fuel pump check fuel pump fuel pump relay fuel filter could be pluged.if you turn engine over acouple turns and stop you should hear fuel pump buzz.also check wires at ignition coil for corrostion or broken fuel pump relay gets its singnal for negitive side of coil.
Why won't it start?
Check fuel pump fuse, if fuse is good, most likely a bad fuel pump vor clogged fuel filter. Without knowing the make and model hard to say where each is located. Fuel pump is most likely in gas tank unless its an older vehicle.
85 HONDA ACCORD WONT STAY RUNNING UNLESS PUMPING GAS NOT EVEN FULL THROTLE
You have a single fuel injector in it right. Try right at the end of the gas pedal cable at the engine there is an electrical plug and a little device that goes around in a circle when the gas is mashed. That is the throttle position sensor. Try unplugging that and if there is no difference in the revving then the throttle position sensor is out. If that is not the problem, then plug your engine into a an onboard diagnostic reader. 85 is an obd1.
2answers
Why wont my car start in the mornings?
Sounds like you are loosing fuel pressure overnight. Could be a fuel pump problem, or a leaking injector.
Car not starting in morning
It sounds as though you are imitating a cold start injector by pouring fuel into intake. I would start there
My 1988 bronco 351w efi has spark but wont start, why?
Check fuel pump pressure. First shoot a little starter fluid into the throttle body to see if it runs. If it does, fuel delivery problem.
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
2answers
I ren out of gas & now my car wont start 1991
make sure the car is on a flat surface ,you can pour a little bit of gas down the throttle body or spray starter fluid in throttle body that should crank the car
Wont start,pour little fuel in throttle body runs 4 little, changed fuel filter,psi seems good off fuel pump
The injecters may be bad, or not getting power.Check wires to injecters @ throttle body to make sure they have not rubbed bare .
My 1985 ranger 2.3 gas FI 4x2 starts and then idles rough, with fluxuating rpm and then stalls. Usually the second time I start it, it runs fine until I turn it off again. Occasionally it will stall while...
Did i answer you before? Anyway, try cleaning the throttle body with a little carb spray on a cloth shop towel wraped on a screwdriver.With the engine off,remove the tube to the t-body,hold the throttle alittle, and spray a couple of squirts inside.Spray some to wet the towel, and pushing it in and out gently of the t-body.becareful not to bend the plate inside or leave any towel inside.look at it with a flashlight to see if it's clean. Hope this helps
Fuel delivery s10 blazer
Did you change the fuel filter?
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
