Question about RCA R52WM24 52" HDTV Projection Television
RWhen the TV is turned there is a harming sound ,and as long the TV is on. When TV is turned off there a loud sound , like a fan has wind down.
  • RCA Master
  • 8,617 Answers
Deflection board needs replacement. You need the ITC222A deflection board PSB-260 You can get the replacement deflection board from www.tvrepairworld.com The boards have a 6 month warranty.
Posted on Nov 05, 2010
Loud hum sound
usually the transformers on the psu would give a slight buzz,but when tv i on standby the only power going to main board is minimum,dont know if your model has aa built in fan,would need model number
Dec 09, 2013 | Insignia Televison & Video
Hear a whirling sound within a few seconds of tv image coming up - continues while watching and winds down when the set is turned off (fan?)
It could be the color wheel in the TV that you are hearing. There is a color wheel that spins in order for you TV to display colors and if it is struggling to stay at the right speed, it could cause the sound that you are hearing.
The fans also make some sound as when they spin and will remain on for a few minutes after the TV is turned off in order to cool the TV.
Nov 03, 2009 | Toshiba 52HM95 52" HDTV Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
The fan or blowwer on my furnace is to loud. how do i fix this?
Hi!!! your fan blower has a capacitor right next to it change that first and test it.If sound is still there then your fan blower windings are getting bad..Good luck..but first change run capacitor .
Jan 05, 2009 | Honeywell Power Humidifier: Furnace...
Loud noise when Tv comes on souns like fan.
The loud noise is the color wheel winding down when you turn the TV off. You need to replace the color wheel.
Nov 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Loud Buzzing Sound - Rear of TV
It is probably the color wheel that needs replacing.
Oct 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
RCA R52WM24 52" HDTV Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
