Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Where can I get a replacemet sponge bit for inbetween the childs legs - Mine fell off and I can't find it and would like to replace it so the strap does not rub on his legs - Any ideas
  • Maxi-Cosi Master
  • 1,629 Answers
Replacement harness pads can be ordered via your local Maxi Cosi retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 10GBP for the set. It comes as a set of three, in plain black only, and if ordered direct there is 3.99GBP p+p.
Posted on Dec 13, 2011
Is there any way to lenghthen the strap that goes between their legs on the chicco keyfit 30 infant seat... Seems to be so short
If your child is over 11 pounds, remove the infant insert (not the head cushion). That may be the issue.
What is the age and weight of your child?
- Marc
CPS-at-marccohen-dot-net
Dec 10, 2014 | Chicco Key Fit 30 (Atmosphere) Infant Car...
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
Do I have to use the safety straps on my kid's high chair? She's a really passive child and doesn't move around a lot but I find the straps are quite restrictive.
Speaking from experience, you should ALWAYS use the safety straps on all your kid's equipment. Even a child that likes to stay still, could suddenly decide to reach for something or get adventurous and take a tumble. My little one fell out the high chair and we spent all afternoon in the emergency (thankfully she was ok), but it's just not worth the risk.
Aug 29, 2012 | Chicco Baby Gear
Making car seat harness larger for child/evenflow discovery 5
You can download this PDF instructional manual for the Evenflo Discovery car seat: https://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHUQFjAH&url=https%3A%2F%2Fplweb.evenflo.com%2FShowDocument.aspx%3FManualID%3D583&ei=A8UtUbW5AY_Z4QSCjoDoCA&usg=AFQjCNFj1O1EuRQVLmKwgOLTJsL6yoeOTQ&bvm=bv.42965579,d.bGE
You can also read this article on how to adjust the harness straps on an Evenflo car carrier: http://www.ehow.com/how_6391052_adjust-evenflo-car-carrier-straps.html
Aug 03, 2012 | Baby Gear
I have a bittax eclipse si and just cannot adjust
below the strap that comes up between childs legs there is a **** in the fabric, stick your finger in & push the top of metal tab..then hold that down while pulling the shoulder straps, pull the straps from the lower half tho, not up high
Nov 08, 2009 | Britax Eclipse Si - Paris Convertible Car...
Lost strap
There is straps called baby buddy that you can get of allbybaby.com that will fit to the stroller.
Apr 23, 2009 | Baby Gear
The straps are too tight on my child
Ok. First don't panic, I did the same thing with mine! lol. In the front of the seat where your childs legs hang, there is a velco flap. Lift it up and you'll see a metal button(but it doesn't look like a button). Push it in and at the same time pull one of the shoulder straps. This will loosen the strap. Then adjust accordingly. If you remove the back plastic piece you will see all the straps underneath if you want to eventually replace them. You can also adjust the height from the back if needed. Good Luck!
Oct 08, 2008 | Eddie Bauer 3-In-1 with Latch
Booster
Remove straps and belt across the lap!
Nov 04, 2007 | Eddie Bauer Deluxe High Back Booster...
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
100 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
