Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Installation not completing
During installation the "Connect the device to the USB port just keeps showing and it appears it is not working to connect. I have checked all connections, but it doesn't seem to be completing.
Try updating the printer's firmware. I had the same problem with my Windows XP machine and my Kodak 5500 AiO Printer. Then, I went to Kodak's website, looked for my printer, and downloaded their firmware update. The only curious thing is that when I ran the software to update the printer, it said the firmware version of the update was the same as the firmware version the printer already had. I went ahead and updated anyway, and now it works!
Just be careful when updating the firmware on your printer, follow Kodak's intructions.
Posted on Sep 09, 2008
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Tip
How to connect a barcode scanner to your computer
<p>If you run a business, you probably need a barcode scanner to help control the items in and out of your iTunes. It is also possible to bar code reader to a computer at home. These devices connect through a USB port like most other external hardware. <br /> <p><br /> <p>1. Connect the barcode scanner to your computer via the USB port. A window showing the computer has detected a new piece of hardware. <br /> <p><br /> <p>2. Insert the CD driver installation. Wait until the installation wizard. <br /> <p><br /> <p>3. Follow the instructions to complete the installation. Remove the driver CD and replace it with a software CD is provided. <br />
on Jun 26, 2011 | Computers & Internet
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
The usb port on the printer seems not to be working. It keeps saying unknown device regardless of the different usb cables i have bought. Can install the printer directly thru the Ethernet port on the...
The first thing to establish, is the problem with the printer on the USB controller on you're laptop/computer. Have you got any other USB devices that are functioning on you're laptop/computer?
As regards to getting your printer working on a ethernet port follow the following instructions.
1. Connect the printer into the back of you're router, using a ethernet cable.
2. Run the installation disk for you're printer, and when promoted select the "network installation" option. If you do not have the disk you can go to the following address:
http://www8.hp.com/uk/en/support-drivers.html
and type in the make and model to download the latest software/driver installation package.
3. You should just be able to follow the wizard on wither of the installation methods and complete the pritner setup.
May 13, 2011 | HP LaserJet 3390 Printer
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Apr 10, 2011 | Computers & Internet
None of my usb ports are working (printer, scanner, thumb drives not working. Computer will not recognize anything plugged into a USB port
when you plug in something go to computer then double click on the object thats in there and select the brand it is.... EXAMPLE: if you have a zune it might reconize it as an ipod
Dec 11, 2009 | Microsoft Windows XP Professional
During installation, device is not detected error appears. tried uninstalling software, unplugging cables, restarting, reinstalling, then plugging cables in. did not work. Windows XP o/s. already checked...
is it wireless or usb, if it usb, dont connect the usb cable. on the installation window where it asks for the usb cable, chek mark on the option connect printer later and continue with the installation
Oct 02, 2009 | HP PhotoSmart 7760 InkJet Printer
Cant connect to lifecam
There may be a clash between lifecam and MSN. close MSN and alll other IMs. uninstall lifecam. restart the PC, install webcam SW with the cam unplugged. After installation plug the cam ina USB port and let Windows read the drivers and install the cam, Once that is done, now you can configure the cam in your IMs one by one.
Aug 07, 2009 | Microsoft LifeCam VX-1000 Webcam
Moden of huawei ETS 2288 WLL
n wista also huawei driver works,,i too tried to install wista drivers for huawei but in vain ..no problem in xp driver itself it will work,,,if it works mail me at aravindterror@gmail.com and don't worry it will work conformly because now im using ny connection in wista using huawei only..
just follow the step to do it:
1)install that driver setup and warning the usb port from modem should be disconnected during this
2)install will finish and wait's for usb port to be connected by displaying port not found,
3)now plug the usb cable and inbuilt windows will appear and say found new hardware and install from the location where you had whether from cd or from hard drive,select appropriate option.4)if it says error during installation ,
4)goto my computer right click and select properties and select device manager in that under other devices categorie you will found your device with question mark,right click that and select update driver and selec from the location where you have that driver back up i.e from cd of location in hard disk..then it will finish installing software and once again it wil ask if automatically it finishes secon time installation no problem or else follow from step 4)
5)now your usb will be identified by your huawei installation process and say port found click next and it will finish setup
6)then once again goto my computer and then right click and than goto properties and device manager and right click on your name at beggining then select scan for hardware changes,,that's all finishes..
7)select connect to from your wista and select new connection and select connect to internet in that dialup ,enter your dial up phone no,username and password..then it will connect....ha ha..
Jul 23, 2008 | Computers & Internet
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
89 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
