Question about Hoover Vacuums
Roller will not turn on hover u57809rm - Hoover Vacuums
    Novelist:
  • 147 Answers
One of the two belts may be broken or stretched on the unit. USUALLY it is the thin flat belt that runs directly off of the motor assembly. Replace the belt on the unit and you should be good.
Posted on Nov 04, 2010
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
Hover uh70400bca the bottom cleaning brush stopped working the belt is good the vacuum part workes good
The brush roller may be clogged with debris, especially inside the end caps. You will have to remove the brush roller and disassemble it to check inside the end caps.
Dec 21, 2014 | Vacuums
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
"Power Brush" attachment doesn't work
When my hover suffered a similar issue i found the problem to be a little stone caught in the part you described as a water wheel, however later i found that one of the connecting hoses from the front of the hover had a little blockage , later, i actually washed the filters and left them to dry over night wrapped in a towel on a warm heater, it was back to normal , the last hover gave in as the motor started to slowly give in , it could be this
Mar 15, 2014 | Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
(hover whisper cyclone)brush stopped rolling checked belt and looks fine what else can it be?
check other side from belt may be a little jam on the rollers on the oppsite side of the belt
Sep 27, 2012 | Vacuums
DYSON DC07 ORIGIN BRUSH ROLLERS WONT ROLL WHEN HOVVERING BURNING SMELL AND SMOKE FROM BOTTOM OF HOVER ROLLERS WILL MOVE BY HAND ANY IDEAS, THERES NO BLOCKAGES.
Hi There,
Ok so I have made a few videos about what to check when you have issues like this.
THere are 3 possible causes.
1. THe bearings in the brush roller are worn so even though you can turn it by hand the belt cannot.
2. The clutch belts are too stretched and are slipping causing them to heat up and start to melt.
3. The roller on the clutch has melted as a result of the heat from teh belt.
From experience the most likely cause is that the bearings are worn and likely the belts are stretched. I will link a video from our youtube channel watch the one I link and then do a search within the channel for DC07 and you will see the other videos.
You should be able to get away with just replacing the bearings or the belts. I will say that if you have got to the point where you are having issues with the front end I would encourage you to replace the DC07 filters too normally they have a similar lifespan.
Jun 13, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Model U57809RM Hoover Cyclonic which started making a very loud noise. Changed both belts on it but the noise persists. It seems to happen when I put the handle in the 'engage to vacuum' mode. The...
You could have a broken fan in the motor and need to replace the fan. If the noise is coming from the brush area of the vacuum, you probably have a broken bearing in your brush roller and would need to replace the brush itself.
Hope this helps.
Jan 29, 2010 | Hoover Vacuums
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
http://dysonmanuals.llc.nu/
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
63 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
