Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson stylus cx4400 printer
I can't figure out how to change the ink cartridge could you help me please
  • Epson Master
  • 691 Answers
This for the CX5400 which is similar with its menu system:
Using the Control Panel Follow the steps below to replace an ink cartridge.
epson stylus cx4400 printer - r_1.gif Make sure this product is on and the On light is not flashing.
When the ink is low:
Press one of the Menu buttons until Change Cartridge appears on the LCD panel, and then press the fontx1.gif Color Copy button. The ink cartridges move to the replacement position. epson stylus cx4400 printer - r_3.gifsrc="http://i.fixya.net/uploads/images/r_3.gif" alt="r_3.gif" class="h_mi" /> Make sure that the document cover is closed, and then raise the epson stylus cx4400 printer - a8101037.gif.
a8101037.gif Caution: r_space.gif
  • Do not raise the scanner unit with the document cover opened.
  • Do not move the print head by hand. Doing so may damage this product.
    Do not start replacing the ink cartridge befepson stylus cx4400 printer - r_5.gif print head stops.
r_4.gif For best results, shake a new ink cartridge four or five times, then remove it from its the package.
a8102006.gif r_5.gif Pinch the sides of the ink cartridge tepson stylus cx4400 printer - r_space.gift to replace. Lift the cartridge out of this produepson stylus cx4400 printer - r_space.gifose of it properly. Do not take the used cartridge apart or try to refill it.
a8101049.gif r_space.gif r_warn.gif Warning: r_space.giepson stylus cx4400 printer - r_caut.gifh_mi r_space.epson stylus cx4400 printer - r_space.gif Be careful when you are handlinepson stylus cx4400 printer - r_space.gifcartridges, as there may be some ink around the ink supply port. If ink gets on your skin, wash the area thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If discomfort or vision problems remain after thorough flushing, see a doctor immediately.
r_caut.gif r_space.gif Be sure to always install an ink cartridge into this proepson stylus cx4400 printer - a8101039.giftely following the removal of an old ink cartridge. If the ink cartridge is not installed promptly, the print head may dry out rendering it unable to print.
r_6.gif Place the ink cartridge vertically into the cartridge holder. Push the ink cartridge down until it clicks into place.
a8101051.gif If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7. r_7.gif Lower the scanner unit.
a8101039.gif The print head moves and ink charging begins. The On light flashes while ink charging is in progress. When the On light stops flashing, ink charging is completed.
Posted on Jun 29, 2008
I have replaced the inks but still getting empty ink warning
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Epson Stylus CX4400 All-In-One InkJet...
Replaced ink but does not workit indicates X's on the new ink
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 20, 2010 | Epson Stylus CX4400 All-In-One InkJet...
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Black ink wont print
Clean the head off where the black is with rubbing alcohol and a qtip. If it won't detect the black cartridge and you went into the printer settings and enabled the black to print as well as the color, then the printer sensor that senses new cartridges and amount of ink level is defective and, unless it is under warranty, it's not worth fixing.
Sep 01, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Hi expert of ESPON CX4400 machine: after I did change a new black ink pack on it, why the on and ink light flash so i couldn't let it work?
Ink cartridge is not seated. Take it out and push in until you hear a click. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Epson Stylus CX4400 All-In-One InkJet...
How do I change the ink cartridge in the epson cx4400
hi, i have retrieved a the manual for you. this is a main link to a bookmarked page where you can access every piece of literature you need form troubleshooting and manual downloads and quick guide instructions on how to install your cartridges.
Click here togo to this page.
Mar 06, 2009 | Epson Stylus CX4400 All-In-One InkJet...
New ink caretridges not getting accepted by epson stylus cx4400
Try removing the cartridges and cleaning the metal contacts with alcohol where the carts sit
Mar 03, 2009 | Epson Stylus CX4400 All-In-One InkJet...
I need to refill my ink for a espon stylus cx4400 printer, don't know where the hole is located at the top to put the ink inside
Epson have designed their cartridges so that refilling is virtually impossible. Believe me a LOT of money has gone into this so I would forget about trying to refill your original cartridges.
Instead I would recommend locating a reseller for refillable cartridges with a resettable chip... Also, be very careful buying any old ink as there are some very cheap, poor quality inks available which are more likely to clog your printhead and drive you crazy. Good brands to consider are Image Specialists, hobbicolors and OCP but there are others out there.
Hope that helps.
Mar 02, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Epson stylus cx 7400
Epson includes step-by-step instructions on changing the ink cartridges in the Printing Preferences menu:
Click the start button and open the Control Panel.
Right click Printers and select Printing Preferences.
Click the Maintenance tab.
You should see a button that says Ink Cartridge Replacement.
Just follow the instructions and it walks you through it.
Sep 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
