Question about HP Office Equipment & Supplies
All the lights are flashing when I turn on my PCS
    Master:
  • 638 Answers
Main board problem 100%.rate this solution as fixya and encourage us to solve more and more problems like yours.
Posted on Jun 14, 2008
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
My printer is hp laser jet 4015 and it is online. it delays unnecessarily anytime one issues a print command from any of the PCs on the network.
Does it actually print? How long a delay are you experiencing? Does the data light flash? There is a known issue with these printers that older versions of the firmware can cause problems with the fuser that results in the printer just cycling but never printing. Current revision of firmware is 04.110.1. You can download from HP website. Download the EASY INSTALL, first option on page.
If your printer is cycling and not printing, this might fix it, but often the fuser is no good and will need to be replaced.
Mar 16, 2011 | HP LaserJet P4015N Printer
Will not print
Please un and re install the drivers for your device following the link below as the dri
Installing Devices on PCs and Laptops
May 12, 2010 | HP Photosmart C6180 All-In-One InkJet...
CHECK PRINTER (5800)
Please un and re install the device drivers following link
May 05, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an iomega ix2 store center and yesterday i lost connection to it. i tried rebooting but after the flashing blue light goes away the red light comes on and i cannot connect.
Kate,
What you must do is that firstly, disconnect the printer from the PC. Then go to Start->Control Panel->Add Remove Programs. Select this printer and uninstall it. Reboot. Insert the driver disk into the drive and install the drivers again. Reboot. Now attach the printer to the PC and allow Windows to detect the printer and load its drivers and give you a message in the right bottom corner of the screen "The new HW is installed and is ready for use". Now it will not give any problems. Also read the following link for complete procedure.
Happy Holidays
Dec 22, 2009 | Office Equipment & Supplies
Can u use the scanner on a hp pcs 1610 all in one inkjet printer without the color ink cartridge?
Hi, the answer is no you cannot, the printer will only work if both cartridges (black and color) are installed, if you install just one the check print cartridge light will flash.
Hope this helps
Muzzi_123
Nov 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
The waste ink absorver is almost full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre to do the service job.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 23, 2009 | Canon PIXMA iP90 InkJet Printer
Trouble networking copier to computer
you might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Oct 23, 2008 | Toshiba E-Studio 3511 Color Copier
Zebra TLP 2844 Error Condition
Qusetion, Using USB my TLP2844 detects as a LP2844ps. Weird, huh? Also when I calibrate it the label does not stop at the perferation. When I print half goes on one label and the other half goes on the next label. Someone told me once there was a trick to get it to calibrate correctly. Anyone here know this? When I print a test page, it feed the correct amount of label.
Dec 04, 2007 | Zebra LP 2844 Thermal Printer
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
