Question about Northstar Professional Series Pressure Washer 4000 PSI
Have a North Star 2500 PPW. There is a hose that will pull soap or other solutions into the spray stream. At what rate does the solution get pulled into the stream?
Soap (Simply Green) is not being pulled from ciphen hose? I unscrewed the brass male fitting, where the clear cyphin hose is attached, and observed a small spring and ball bearing? Nothing appears wrong,...
The system uses a Venturi format to transfer the soap into the line out. If there is a leak of any sorts, the vacuum component is compromised and it will not allow the soap to mix with water and flow as usual. If the soap is too dense for any reason, that too is a problem. Try to thing the soap solution to make it easier for the mixing process to evolve. If that fails, you may have to replace the bearing/spring assembly.
Feb 05, 2018 | Briggs Garden
What kind of soap do i use and do i use it strait or mix with water i have a 2600 just a hose i think is for the soap
most solutions are sold to be used as is , place the tube from the washer into the cleaning solution as you spray it will be mixed with the spray water . the kind of cleaner depends on what you are cleaning . you can buy cleaner for decks or cars or house etc.
May 15, 2011 | Honda 2500 PSI Gas Pressure Washer
Will not take detergent from resevour
First check the intake line, filter and the brass fitting on the pump for obstructions. It clear it's usually because you are using a high pressure tip on the gun while trying to spray detergent. The only way the system can pull the detergent into the water stream is if you are using a soap tip (usually black) on the gun.
Nov 16, 2010 | Honda 2500 PSI Gas Pressure Washer
Sometimes the flow indicator doesn't spin even tho it has solution. I've tried loosening & tightening the lid. what else can I try?8910 Bissell proheat
noavatar_s.gif xpinto
Rank: Apprentice
Rating: 0%, 0 votes
I wasted a lot of time following the expert advice to repair my unit by taking the cover off of the main unit and using compressed air to blow out the lines. The problem turned out to be in the lower panel of the handle (4 screws to remove). The heater is a large block of aluminum with a stainless cover held on by screws. The lower nozzle of the heater was blocked by water/soap reacting with the aluminum while in storage. Blowing out the lines as recommended with air compressor just warped the stainless cover resulting in time spent flattening this back into shape.
I would recommend the following steps:
1. Make sure that fluid levels are up in both the supply water bladder and the soap dispenser.
2. Pry off the left side access cover and ensure the pump drive belt is still in position. Switch the unit on and see that the pump is spinning.
3. With the unit plugged in and the handle laying flat on the floor (using the foot release lever) , remove the clear bezzel over the red impeller, switch the unit on, and pull the trigger for soap. Liquid stream should shoot straight up past the impeller. If not the lines are plugged somewhere.
4. Unplug the electric power. Remove the four screws and remove the lower handle access cover (with the red light in it).
5. All the fluid lines are clear plastic so you can identify which have fluid movement.
6. Disconnect the line from the soap activation switch (pliers on the squeeze hose clamp) feeding the heater (large aluminum block). Blow air (with your mouth NOT the air compressor) into this line and see if fluid movement is observed in the clear plastic lines. A little tentative about soap in your mouth, use a turkey baster filled with water). I saw no movement of liquid. Nozzle exiting the heater blocked.
7. Remove this hose and use a small drill bit to twist the debris loose. You may elect to remove the heater shinny cover for better access. Gaskets are reusable. Blow thru the hoses again to assure blockage cleared.
8. Button unit up.
9. With the clear bezel off and the red rotor exposed, plug unit in, soap and water supplies in place, switch on power and pull soap trigger. Should see vertical stream. Mine was about 5 inches initially then jumped to about 10 inches high. Knew blockage was cleared.
10. During shampoo operation if soap stops (red impeller stops spinning) first check fluid levels and fill. That doesn't work, I unscrewed the clear bezel and pulled the soap trigger with the unit switched on. Less than a second vertical stream appeared every time.
11. Now you know how to fix and achieve continuous operation.
12. The unit must be thorougly cleaned before putting it away for storage to prevent the reoccurance of the blockage in the heater. After following the manufacturer's instructions, by flushing (operating the unit) with clear water in the bladder and the soap dispenser, I did one final thing. By removing the fresh water storage/collection plastic container, a black round fitting is exposed that channels the water from the bladder into the spray system. I used a length of automotive heater hose that was the same diameter as the seal on this fitting (turkey baster with bulb off will work) and blew hard while the unit was switched on and the clear bezel was off. One last big blast of water spewed from the unit. This cleared all the lines from the bladder through the pump, switch, and heater and blows it out just prior to the spray nozzles.
This is long but specific.
Not so technical, take each step as presented.
Good luck.
Plano Tx
Oct 13, 2009 | Bissell 8910 ProHeat Clear View Upright...
My weber gas go anywhere grill is alot more flame on the left side of the grill and the right side of the grill has very low fire even when turned on to high? p.s. the grill is brand new
Even a brand new BBQ makes a happy home for spiders. :)
1. Pull out the burners. Use a can of air or the equivalent to clean them out.
2. Disconnect the regulator from the feed hoses(if possible) Blow the hoses out. Check the regulator for obstruction (even a little bit of fluff, or a tiny spiderweb makes a huge difference) There will be a screen on one side of the regulator.
3. Reconnect and ensure connections are leak free. A soap solution sprayed on joints works well for this. Clean up soap solution thoroughly as some solutions can degrade piping.
***N.B. Do not apply a greater deal of air pressure to the regulator itself - it is rated for 1 - 5 PSI _AT MOST_ ****
Aug 05, 2009 | Weber Gas Go-Anywhere Grill
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Water trickles out of sprayer head on pull out faucet.
Hi crossroadsjm,
I'm Harvey the Master Plumber.
Your problem is: soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine.
It is very possible that some debrie has come up in the water and is partially clogging the faucit. For this you would have to turn the water off and disassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 14, 2008 | Price Pfister 532-7PCC Marielle Pull-Out...
Got a karcher 410 water pressure passed down to me without directions need help working it
Fairly simple to opperate. Connect water supply hose. Connect wand hose. Plug in, turn on water supply and turn on. Then squeeze the wand handle to spray. With mine, there are times when the unit looses pressure, but if you leave it running, it seems to recover. Also note that you can turn the flare at the end of the wand for a soft stream versus pressure spray. I have had mixed results with the pull out clear tube that is supposed to siphon liquid soap into the mix.
Apr 05, 2008 | Washing Machines
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Northstar Professional Series Pressure Washer 4000 PSI Logo
198 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
