Question about Vacuums
Wind tunnel by Hoover, vacuum will not turn off by using switch on upright handle. do not see a way to get to switch. modle no. U5458-900
  • Anonymous Jul 06, 2008
    same problem poor design. switches on but not off . the slide that pushes against the rocker swith is to weak to turn the switch off.
  • 77 Answers
Follow the cord and look for screws inside the bag compartment at the top. a panel should lift off allowing access to switch and cord. If swtch is melted it must be replaced with special hoover switch kit which has new wire and heavier duty switch. be sure to follow original path of cord to switch.
Posted on Jun 14, 2008
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Can I get a replacement handle for a hoover wind tunnel upright? It snapped off
That part is available. Includes the handle, cord and "digital" switches. Here's the link:
Good Luck!
Vac Dr.
Sep 29, 2012 | Hoover UH30010COM Bagged Vacuum
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover wind tunnel vacuum will not turn off
You will have to replace the switch, Takeout the 4 screws on the back of the handle, it will slide off, then from the front, take out the 4 screws that hold the tool compartment on, it will then lift off and you can access the switch.
Jan 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Dec 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
