Question about Sanyo TLS-4960 VHS VCR
My Sanyo TLS 9072 records fine, except for it is "jumping screens" ?? Not sure how to explain this but here it goes: I have the monitor set to show 4 channels. Which look fine, only it jumps from the four channels I have it on to the next four channels, which are not set up so they appear gray. Therefore my recordings are having a blank screen that lasts about 4 seconds. I need this problem fixed. There is a "P" on the screen due to a power failure, but I can not reset it. Before this "P" occured everything was running fine. I do not know how to fix this problem, I have an Instruction Manual but it doesnt cover this particular solution to my problem! Please help ASAP! I need not have 4 seconds of blank screen recordings. Thanks in advance!
SOURCE: Sanyo VWM-406 recorder
how to hoopup sanyo vwm-406
Posted on Feb 05, 2008
bugpowder
  • 28 Answers
SOURCE: recording
You should set the VCR to the channel which you want to record. It doesn't matter what channel the TV is on. In your case, just turn off the TV.
I making assumptions about your setup. If you can turn on your VCR and TV and watch the channel that you will be recording, then just turn your TV off, and you should be good.
Only caveat, some VCRs must be turned off while waiting for the recording timer to activate (presumably, so as not to interfere with someone actively watching a program).
Posted on May 19, 2008
SOURCE: I have a Sanyo digital
I also can not find a manual for the Sanyo Digital answering machine DAS485
Posted on Aug 16, 2008
  • 275 Answers
SOURCE: Trouble with Sanyo video recorder
Dear Lynn,
Have you some experience in opening and repairing Electronic equipments? Or does your husband / partner have any experience?
From what you have described, it seems that one of the belts has snapped or become loose.
Unplug the VCR, opem the bottom cover, and check the belts. If any of them is loose, or snapped, replace.
Posted on Aug 19, 2008
SOURCE: sanyo plv z5 projector says my bulb needs to be changed but
look at
http://www.digitalhome.ca/forum/showthread.php?t=63757
solution is there !
Posted on Nov 29, 2008
Hi i have a sanyo xacti vpc-ca100...there is no picture on screen when i want take a picture or record ...but everything else works fine menu setting playback of stored picture etc...
Are you sure the lens is actually opening ? Next time you use it, examine the front of the lens to see if the lens cover has opened. If it has not, that is the reason. You may be able to get it repaired, but at a cost.
Aug 08, 2016 | Sanyo Cameras
Black screen external monitor works fine
Replace the screen as the external monitor is OK.
Apr 14, 2014 | Computers & Internet
Exchange server returns "an invalid email"
The sending or receiving mail server probably requires an encrypted connection (not accepting unencrypted ones) whilst the other party doesn't support encryption. In technical terms 'a secure ESMTP/TLS connection'... You should contact your system-admin about that, explain the issue and provide him with to complete error-message mail.
Apr 02, 2014 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Hotmail account can't connect to the server. tried all advise with pop3
The outgoing server probably requires authentication (usually the same password as for the incoming server). Is your email client sending authentication? Look for a checkbox saying something like: "Outgoing server requires authentication."
Also, I just want to make sure that you can't use "smtp.live.com-25-TLS as the address for your server. The server is smtp.live.com, the port is 25 and encryption is TLS.
Oct 22, 2017 | PANDIGITAL Novel 7
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Apr 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
DRW-1000 Sanyo DVD/VCR combo
go to web site http://www.retrevo.com/s/Sanyo-DRW-1000-DVD-Players-review-manual/id/311dj889/t/1-2/ when it opens, click on download the manual (it's a PDF) I copy/pasted to my computer files. It's about 60 pages worth...............Hope it helps.
Aug 31, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo TLS-4960 VHS VCR Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
