Question about Pioneer SD-533HD5 53" Rear Projection HDTV
No power When turning the power on, it will for just a split second, go on then turn back off, I have unplugged it and then reset the adapter but still it willnot stay on.
  • julia69 Jul 02, 2008
    TV green on light comes on for 2 seconds and that is all that it!
  • nparker Jul 16, 2008
    I have the same problem. Does anyone know how I can fix this myself??
Open the back of the tv look on fuse board about middle loacation center there is a group of fuses very small should be a 2.5 amp fuse that is blown. had same problem watch tv repair guy fix once and have done it now 3xs myself.
Posted on Jul 24, 2008
I'm having a very similar problem, basically its a fuse that is blowing out, I think the transformer is sending too much power it's way.
Posted on Jun 15, 2008
I need to reset ink hp c7200 plzzzzzzz
Hi just try this instructions
Press the on button to turn off the HP All-in-One.
Unplug the power cord from the back of the HP All-in-One.
Unplug the power adapter from the wall outlet and wait for 30 seconds.
Plug the power adapter back into the wall outlet.
Plug the power cord to the back of the HP All-in-One.
Press the on button to turn on the HP All-in-One.
Apr 18, 2011 | Office Equipment & Supplies
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
Printer will not let me copy or receive faxes.
Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
May 29, 2010 | HP Photosmart C7280 Printer
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Unit will not turn on anymore
First reset all settings of your router to factory defaults.
You can reset it with RESET button it is in back side of router.press it for 10 seconds.
Then check led status.
Disconnectr all connection from router then reconnect then check.
Soemtimes power problem create this problem .
Change your main power supply also check after change power adapter.
check ADSL cable ethenret cable to .
If still face same issue then your router has some hardware issue.
Let me know if you need more assistanse.
Thanks.
Sep 03, 2009 | Computers & Internet
My Wii console won't turn on.
First:
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
Third:
Fourth:
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
Wii won't turn on!!!
Try resetting the AC adapter.
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 03, 2009 | Nintendo Wii Console
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Hp c7280 all-in-one printer will not shut off
I'm assuming your printer power button will not shut the printer off. You can unplug the power connector from behind the printer if it won't shut off via the power button or power switch.
Apr 20, 2008 | Office Equipment & Supplies
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
79 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
