Question about Apple iPod nano 3rd Generation
Sleep timer for ipod nano 3rd gen
How do i set the sleep timer on ipod nano 3rd generation
  • Anonymous Mar 23, 2014
    5th generation
  • Apple Master
  • 2,794 Answers
Go to extras. Select clock. Press enter on you clock settings. Select sleep timer.
Posted on Jun 14, 2008
My ipod nano 6th generation sleep\wake button is compressed. how do i fix this problem
This is a pretty simple nano repair and the part only cost $19. iRefresh can install a new one for you for $44. This repair includes new volume electronics aswell. iPod nano 6th gen Power Sleep Button Repair
Apr 24, 2011 | Apple iPod Nano 6th Generation MP3 Player
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Have 4th gen ipod nano, charged it up but dont
theres no switch of on ipod, only sleep, just dont forget to sleep and lock it if your not gonna use it.:)
Sep 30, 2009 | Apple iPod nano 3rd Generation
Ipod nano 3rd gen says I have less space than I do
Yes, it does seem like a rip off, but that little bit that seems to be gone is actually being used by the software that makes the iPod work, without it you would not be able to use your iPod at all. So don't worry, it is completely normal that you are missing half a GB.
Aug 22, 2009 | Apple iPod nano 3rd Generation
My 3rd gen. ipod nano is frozen
just press the menu and power botton at the same time. that reset your Ipod
Aug 13, 2009 | Apple iPod nano 3rd Generation
My ipod nano 3rd gen won't do anything won't power on wont charge
If you go to www.rapidrepair.com you can view totally free information about trouble shooting this issue as well as learn helpful tips for future reference :)
May 21, 2009 | Apple iPod nano 3rd Generation
I locked my ipod and forgot the code
If you have a third gen ipod nano and you locked the screen lock and forgot the code, well what you do is you hook your ipod to your PC,laptop ect. and disconnect it. It should be unlocked. But if you lock it you have to do that over again to unlock it.
Oct 06, 2008 | Apple iPod nano 3rd Generation
Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 07, 2007 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
205 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
