Question about Hampton Bay 42 In. Antique Brass Landmark Dual Mount Ceiling Fan
Chain stuck My chain that turns the lights off and on is stuck. How do I fix this?
  • Anonymous Oct 07, 2008
    chain stuck on ceiling fan
  • 61 Answers
Change the switch. Sometimes gently yanking on the chain releases the jam. More often than not, the switch needs to be replaced which requires dis-assembling the fan.
Posted on Jun 22, 2008
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
How to fix pull chain for lights on a ceiling fan?
You will probably have to replace the switch that is controlled by the chain. You will need one withe the same number of wires coming out of it. Find out the type of fan and google it. If it is a cheap fan I would replace the entire unit, it if is also old.
May 01, 2015 | Hampton Bay 24002 Ceiling Fan
The timing chain jumps when i turn the engien
check cog teeth ok and the chain guides are located properly , also that the chain tensioner is not stuck , some have adjustable ones or fixed so check these !
Dec 03, 2013 | 2008 Daelim Roadwin R 125 FI
Model: 21647 chain is stuck for light
When you say stuck I assume you mean it is stuck in the fan. You have to carefully unwind the fan to release the chain pulling slightly as you unwind.
If the switch itself is broken they are an easy fix from any home repair or electric supply house
Mar 11, 2012 | Hunter Caribbean Breeze 21647 Ceiling Fan
I have a hampton ceiling fan and the chain for the light switch is stuck...what should I do?
The chain is easily replaced or repaired, sometimes just a drop of oil will get it slipping again. But the hardware store carries the little pull chain switches , they are a fit all. Turn off the power if you are worried about getting zapped, just take of the wire nuts from the old switch and replace the switch, hook the wires back up just how they were, you should be all set. Check it out.
Jun 22, 2010 | Solar 2-wire Pull Chain Light Switch For...
The pulley chain broke on the light on my ceiling fan and there is no slack to turn the light on or off. Can you please tell me how to fix or replace pulley?
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
Jan 20, 2010 | Solar 2-wire Pull Chain Light Switch For...
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
Oct 01, 2009 | Hunter 22451 The Brookline Brushed Nickel...
The chain is stuck on chain saw. I can't loosen it, it will not rotate when motor is on and the motor will not turn over the blade is stuck
Try taking the chain guide off, so you can remove
the chain. This will free the stucked up chain.
Replace the chain guide, and the chain. Hope this will solve your problem.
Sep 23, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 42 In. Antique Brass Landmark Dual Mount Ceiling Fan Logo
336 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
