Question about Blaupunkt Car Audio & Video
I have a 2001 Blaupunkt 10 CD changer. I believe it's a model CDC-A-03. It just stopped working. When I select the changer it gives me a "check 1" code on my radio screen. Help.
  • rap98026 Jun 22, 2008
    The model number of the CD changer is CDC A08. The changer has been in my Honda Odessey since 2001. I recently had a Blaupunkt Key West professionally installed
    because my original radio was having volume control problems. Everything worked fine for about three weeks. One day when I was going to the CD changer mode it failed.
    All I get is a readout of "Check 1" on my radios display. I returned to CarToys to have
    it troubleshot but to no avail. Help
    Brigadier General:
  • 3,614 Answers
What kind of code did it say..?
Posted on Jun 21, 2008
  • 4,889 Answers
Sorry can yu get me the error code again?
  • eagle338
    eagle338 Jun 22, 2008
    I Think there is a mechanical problem with one of the trays.. Did you try a different CD tray? Also Try a original pressed CD, and see what happens
  • eagle338
    eagle338 Jun 25, 2008
    What happened did you try what i suggested?
CD changer skips on bumps
There are two ways either the 90* or the 180*. If your having problems like skipping I'd suggest finding a place at the center of the car where there is less shock for the unit, like under your seat. I know changers have this 6 seconds or more memory so in case it skips, the first 6 sec ahead of the song is stored and play it to avoid the skip.
Oct 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
2002 Explorer indash cd changer malfunction 'cd error'
its an optical problem, you may try cleaning the lens or try replacing a new one.
Jul 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Pinout of Round Connector on CDC A08 ?
See this diagram.
http://fileshare.eshop.bg/index.php?what=search2
(search for CDC A08 if link doesn't work)
Basically, 12v to pin '3' (with notch at top, it's the top row, third pin from the RIGHT) and ground to outter jacket of the connector. Push eject button, works a charm.
Cheers.
Mar 27, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Apr 15, 2008 | Car Audio & Video
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Car Audio & Video Logo
173 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
