Question about Dishwashers
NO WATER GETTING IN - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Nov 06, 2010
The water isn't getting hot
Hi Carl:
First, a question for you......
Did you just install this washer, or maybe do some maintenance?
The reason I ask is that there are 3 possible reasons the water is not getting hot.
1) There is no hot water available at the supply.
2) The supply hoses have been reversed and you're getting cold water when the machine thinks it's getting hot water.
3) The settings on the machine are requesting cold water. Check the dials.
Hope this helps.
Cheers.
Feb 23, 2016 | Washing Machines
Not leting water in on modelsyo424a
Have you checked the water valve solenoid with a volt meter to make sure your getting power applied when calling for a fill cycle? if you are getting power and you can hear the water valve make and not getting water into the sump tray then have you checked the water filter? Make sure water supply line is not kinked and you are getting water to the valve.
Oct 07, 2014 | Kitchen Appliances - Others
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Ice machine not getting water
Change the dual water control valve if not getting water during cycles.
Sea Breeze
Jun 08, 2012 | Kenmore Refrigerators
Water is getting into my car
hi vfolkswagond you should check from were the water getting in, if the water getting from the door you should check if the rubber is in his place if not put hit in the right route, if the water getting from the roof you need to check the antenna hole if it dont seal you should use epoxy glue that fit for cars
Jan 11, 2011 | 1997 Ford Crown Victoria
HOT WATER NOT COMING INTO MACHINE
lets see hear.what the water fill hoses are connected to is call the water fill valve.when you select a water temp.,electricty will then go to ither water valve coil or both for warm.so if your not getting hot it could be first that the fill screens at the hose at the water valve is blocked .but most of the time thats not true of hot because minerals drop out in the water heater before getting to the water valve,unlike the cold water.so if screen is clean,next would be voltage to the water valve.if its getting voltage but not working then its the water valve.if its not getting voltage then use the wiring diagram to see what componet is before the water valve.may be water selector switch or timer
Jan 03, 2009 | Maytag HAV3460AWW Top Load Washer
I am not getting water thou the ice maker nor the water dispenser
Check the water valve where the water supply line comes into your frig. If you are not getting any water at all then it seems as though there is no water getting to the frig through the water supply line or the water valve is bad or not getting any voltage to work properly.
Nov 14, 2008 | Whirlpool 21.7 cu. ft. Side-by-Side...
Frs26xgc
YOUR WATER VALVE MIGHT BE FAULTY AS THE WATER TO THE FRIDGE IS OK BUT THE VALVE IS NOT OPENING TO ALLOW THE WATER INTO THE ICE MAKER HAVE THAT CHECKED.GOODLUCK.MOHAMED
Sep 11, 2008 | Frigidaire FRS26R4A Side by Side...
Dishwashers Logo
Top Dishwashers Experts
