Sony STR-DB780 Receiver Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connection monitor out to the tv i havent got a manual so cnt access settings to tell receveir to perfprm the task
Anonymous
Level 3:
Guru:
  • Sony Master 2,178 Answers
  • Posted on Nov 04, 2010
Anonymous
Sony Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390424
Points
6614
I need to change my mobile number on my yahoo mail account but i cant remember my password
Hello Lizanne,
As long as you remember your own email address
you should be able to get YAHOO to perfprm
a PASSWORD reset... and regain full access
to your account profile...
Carnac the Magnificent
2answers
I have a 42" samsung plasma Model PS-42C91HD. When I connect my laptop to TV I am unable to get a picture. I think I have the right connections. What mode do I watch it in (ie AV1 etc..) or watch setting...
First tell me, how did you connect the laptop to the television what connection did you use? did you use VGA or Svideo?
Heres a video on how to enable the 2nd monitor or svideo to get picture to the tv, ones you have set it to the right channel. Depends on what you connected it to?
http://www.svideo.com/displayvideo.html
Cnt access team lava games says cnt find internet connection
You can contact Team Lava which is now storm 8 on this link
Storm8 Contact
I want to use my television as a computer screen. How do I switch the television to proper mode?
Look for a button on the remote or the TV itself labeled Source or Input. This should let you change the input between TV, AV, HDMI (on some TVs), and PC. Just press the button repeatedly or use the up/down arrows.
Before setting the input to PC (VGA), turn off the TV and the computer. Then connect the VGA cable (M-M) and the audio cable (a 3.5 mm M/M cable, if you plan to use the TV speakers) between the two units. Next turn on the TV and set the input to VGA. Then turn on the computer. (This is if you are using the VGA or D Sub 15 connection.) For a desktop, if you do not have another monitor connected, the TV should automatically be detected and the resolution set with any Windows OS (XP and later). However, you may need to reset the resolution and the refresh rate. For Windows 7, right click on the display and choose Screen Resolution.
For a laptop, you may need to enable the video port in the BIOS. Accessing this depends on the manufacturer of the computer motherboard. (Often Esc, F1 or F2 is the key to press after turning on the computer but before the OS loads. This can be tricky to time correctly.)
With a laptop or a desktop with another monitor attached, you will need to tell the computer how to deal with the multiple monitors. (Extend, monitor 1 only (or laptop internal monitor), monitor 2 only (external monitor), or dual display.) For my HP laptop with Win7, I choose Graphics Properties instead of Screen Resolution. There may be a keyboard Fn shortcut to access this.
Some TVs will accept a PC signal on the HDMI port (directly from an HDMI port on the computer or via a DVI to HDMI cable). Not all TVs do this. (Without the model for your TV, I can't confirm if this will work. If it doesn't, it is because of the differences between the PC output signal and that of set top boxes (cable or blu-ray players).
I hope this helps.
1helpful
Cannot activate gprs
they have 2 ways to active the GPRS setting
1st click your sim card then click the GPRS on then they send you a configuration access all you have to do is to save it. 2nd you call your network operator then if you call the operator and talk about your concern about they havent send you a configuration. they will tell you manually your configuration access and do it to your phone manually .
hope it will helps you a lot .
Jul 18, 2011 • Cell Phones
1helpful
Hi, When I connect my Samsung RF711 laptop to my Sanyo LCD-42XR9DA TV HDMI to HDMI, and source the HDMI 1 input and press OK I do not get any laptop display on the TV screen at all. I have spoken to both...
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
1helpful
How to use my samsung wave as a modem
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem You need PC suit software provide by SAMSUNG
To use your phone as modem *install the pc suit software *Open PC suit and select "Connect too internet" *if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet For this you need *Bluetooth on your PC and phone
To connect(in windows OS) *Click on Bluetooth symbol on task bar *Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode) *Add your device to your pc Add completion of the above...
*Again click on bluetooth symbol on task bar *Select "show all devices" *now select your device(one click) at this time 4 options appears on top your devices list *select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar *Select "show all devices" *double click on your device *select connect to internet from the dialog box which appears after selecting the your device
Thank you
Dvd recorder set up
there are some tv (sony) that you can get video and audio out from the tv and then is simple task to record what is in the tv. But maybe you don't have that option.
the second idea is this:
Think in the signal that comes from the box as a river and you need to divide this river (signal) before gets to the tv, so feeding the signal to the tv and the set you use to record then you have the option to record and watch the tv as regular; only task to do now is to monitor the recording in the input where you assigned for the dvd recorder. i hope is clear the idea to you!
2answers
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
8helpful
2answers
V-chip reset
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up]. 2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
