Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi VS-50705 50" Projection TV
Comment by f_crabb, posted on Jun 14, 2008 Thanks for the advise, I have been looking around the signal board and where the capacitors you told me to change I cant see any leakage. However there is some leakage around the Antenna input connection. I took the box ( antenna input box) off and there is a really sticky, clear liquid that is rather thick on the bottom side of the little box and on to the board. Could this be the problem? I tlooks that the liquid came from this somewhere but I cannnot find the source of it by looking. Please advise, thank you very much!
  • Frank Crabb Jun 14, 2008
    Ok, whats the CRTS? Are you talking about the silver box that has the three coaxial connections that plugs into two vertical silver boxes? It looks like the liquid is coming from the silver box, which is elevated off the board, in which the ant input plugs into. I took the side cover off and found no evidence in that part. Could it have come thru where the ant input plug into the two verrtical silver boxes? Thank You very much for your help!
  • Mitsubishi Master
  • 8,617 Answers
I jus posted a response to tell you where else to look for that liquid as its most likely the CRTs leaking.
Posted on Jun 14, 2008
  • Sonny Berry
    Sonny Berry Jun 14, 2008
    Crts are the picture tubes. the coolant can drip down onto the chassis fro above at the top of the picture tubes.
Toshiba tv when the TV is on it blinks off and on as you watching it
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 11, 2017 | Toshiba Televison & Video
Samsung mod.rl40 takes to long to come on after switching of
Jan 11, 2017 | Samsung Televison & Video
EMERSON 55 INCH TV MODEL: LF551EM5 SERIAL: DS2A1433113216
Jan 10, 2017 | Emerson Televison & Video
We had a power outage and since my tv does nothing, a tiny red light says standby but nothing changes.
Jan 10, 2017 | Televison & Video
I am getting pastel vertical lines down the right side of my Mitsubishi 40134. Is it fixable?
The TCON board or the LCD panel is Faulty, Can confirm by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 09, 2017 | Mitsubishi Televison & Video
24inch Bush smart TV/DVD not working.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 09, 2017 | Bush Televison & Video
Samsung plasma TV model #pn42b400p3dxza problem with no image. The TV has sound but no image. I've tried using other components on the TV like RCA jacks with a separate TV digital tuner. Thank you
Check whether Va & Vs voltage come to the display panel, from the main power supply regulator board. If not, the SMPS board [power supply regulator board] is faulty.
Jan 08, 2017 | Samsung Televison & Video
I was using my Samsung LCD 40" - LE40M86BD [R] when it just switched off and wouldn't come back on. What could it be? Thanks guys
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. . If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 07, 2017 | Samsung Televison & Video
The color on my TV is all pink. I have tried a hard reset but it didn't help.
Your TV has lost a GREEN color from a basic color palette (Red-Green-Blue). It is often caused by:
- damaged LCD cable (which connects the display with a signal board inside the TV),
- damaged video signal cable (ex. SCART, HDMI, VGA),
- damaged video processor (on the signal board).
I can't give you a more accurate answer, because I don't know what is your TV mark and model and, in what situations you have the problem.
Jan 19, 2015 | Televison & Video
Mitsubishi VS-50705 50" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
