Question about Lexmark X4270 All-In-One InkJet Printer
I need to upgrade my OCR software when I Scan a document to edit my text format is different from my document. My all-in-one works good except when it comes to saving my scanned picture with text. I get a message saying I need to re-install my OCR. I re-installed my disc that came with the all-in-one and it still doesn't help. Also, the product does not complete a print job unless I unplug the UBS and re-plug it again.
    Guru:
  • 1,049 Answers
Go to the Lexmark website and download the full install for the printer application or run the setup on the CD. "Driver only" installations through Windows Add/Remove Hardware might not add the OCR components.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jul 23, 2008
I have a Lexmark x5650. I'm on a mac, upgraded my os from Tiger to Snow Leopard. Now I can't scan OCR text. Could scan to word document before, and get editable text. That is not an option now
If you still have the Lexmark X5650 install disc that came with your printer, re-insert it to your computer hard drive and run the program. This will help repair the OCR scan software and possible corrupted files necessary for scanning documents.
Jan 12, 2012 | Lexmark X5650 AllInOne InkJet Printer
I now have office2010 how do u scan a form in to be able to type on the form?
what you want to do, is not possible. Only way to properly write on a form, is that you have the original digital computer version of it, sure you can scan it, but you can not use / write on the same way. Sure you can use the computer to ADD text into the form, if you scan it as a picture, and then use the Microsoft paint program to add text on the fields. But its not the same as having the original digital form to write on.
Or then I'm not informed on how to Scan a form, to turn it into a form and then to fill out that form on your pc.
Sep 28, 2011 | Microsoft Office Home and Student 2010
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
Scanning document and editing in word
Hai,
HP Solution center software installed for your printer model has OCR feature to edit the scanned text image, but its not guaranteed.
Optical Character Recognition (OCR) programs cannot reproduce a document with 100% accuracy every time. Some manual correction of the page is necessary.The following information might help increase the accuracy of the OCR.
1.You must click Scan Document from the HP Solution Center to begin the scan for the OCR to work.
2.On the Scan Document Button window, select a compatible program in the Scan to drop-down. The perform OCR setting then appears to the right.
3.On the Scan Document button Window, select the Scan Document Settings button.
4.Make sure at least 300 ppi is selected.
5.Remove the setting from Flowed Text in the Scan Settings window. If it is not already selected, select it now.This option will work correctly only in word processing programs capable of accepting this type of output. Microsoft WordPad, for example, will not accept this type of output.
6.Repeat Step 5 with the Retain page formatting setting.
Note: If the above solution didnt work, then you have to buy third party OCR software.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
How can I scan a documtent and save it in my word processor
A scan of a document is only a picture of the document. That is, it's the same as if you had just used a copying machine. It's not text that you can work with. You need to take that scanned image and feed it to an optical character recognition (OCR) program to convert it into text that you can use. Most scanners come bundled with OCR software when you buy them. You can also look on the internet for OCR programs.
Once you have OCR software installed, many scanners will automatically feed the scanned image to the OCR program when you scan a document. Be ready to do some extra work, though. While it's good, most OCR software is not 100% accurate. Depending on the font and formatting used in the original document, the program may decide on the wrong character when converting. You will also lose formatting (font sizes, types and so on), and end up with plain text. You'll need to put that in yourself when you paste the text into your Word document.
Jan 29, 2010 | HP DeskJet F4280 All In One Printer InkJet
My document won't give me ocr as an option for editable papers..will only scan as an image..
It's not the printer or scanner, it's the scanning software on your computer that enables OCR. Most free programs won't do OCR, You need something like the add-ons available with Adobe Acrobat.
Oct 14, 2009 | HP PSC 1410 All-In-One InkJet Printer
Want to scan in a text document and edit it in microsoft office I have a epson Dx8450 scanner
you need to see if your scanner has any OCR software. If it does it needs to be scanned and processed through it to create a document you cane dit.
Oct 04, 2009 | Office Equipment & Supplies
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
go to the manufacturers website and download any updates you may need. It would have been helpful if you mentioned your Model # and software version.
good luck,
djEnigma
Apr 01, 2008 | Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
