Question about Maytag Neptune FAV6800AW Top Load Washer
I bought this used 6 mo. ago. the previous owners said it ran great but needed detergent dispenser that locks into the lid. searched everywhere to find one. got it, put it in, and it ran great aside from the constant random beeping and pauses for no apparent reason. have to unplug it when not in use just to shut it up. none of which is my real problem. I bought the dispenser from reliable parts(NOT so RELIABLE!) it has only been 6 months and the brand new dispenser broke again in the exact same place! the little plastic clip at the top snapped clean off. is there another replacement part for it that is stronger? I am NOT going to continue to replace this every 6 mo.
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Usually a suspension problem causes the detergent dispenser to break. A weak suspension strut socket strut & bushing Item 4 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169371&diagram_id=1327946#d1327946
will allow the tub to oscillate too much so the result is a broken detergent dispenser.
The procedure is on page 42 and 43 of this manual: http://www.appliance411.com/PDFdocs/16022808.pdf
Look at the picture of the rear strut on page 41 and ensure your rear struts are sitting in the mounts properly.
Rear struts are Item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169371&diagram_id=1327945#d1327945
Lastly make sure the unit is level with none of the leveling legs allowed to float above the floor.
Once you solve the suspension problem you should no longer have beach dispenser breaking problems. Take some time and read the 1622808 manual (our Bible) above paying close attention to many of the notes from pages 40 - 45.
Thanks for choosing FixYa,
Kelly
Posted on Nov 04, 2010
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Hello What does the error code A13 represent. The soap dispenser seems Ok. Could it be related to something else. The machine starts up Ok, but about 6 seconds into a cycle A13 flashes up and the...
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at this site.
Mar 20, 2011 | Indesit 24 in. DE73 Evolution...
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Dishdrawer leaves dried detergent and crud on
1-Go to diagnostic mode.
2-Press the Start /pause button until you get the display rd for Rinse Aid Dispense setting.
3-Have warm water readu in a kettle or a pitch.
open thedispenser to pull water in.
press the Lock button to turn the dispenser on.
4-Continue to pull water onto the dispenser holder so it can flush out all the resisdue.
5-When you feel that it is enough, press the Lock button again tostop it.
6-Press the power button to get out of this mode.
7-Start a Rinse cycle to completely flush out the residue from the inner tube to the sewage.
8 The next run you won't see the white stuff anymore providing that you will use the liquid not the powder...
Jul 03, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
I have sand in tall glasses when washed on the top shelf
jalexandruna the lid you opened on the dispenser that has 1-6 is where you pour in the rinse aid. As to if it will help or not, this sand issue may be hard water. Try using a eviromentally friendly detergent which is high in Citric Acid. Or try running a dishwasher cleaner like Dishwasher Magic thru the dishwasher to clean this residue out. Hope this helps
Feb 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Neptune FAV6800AW Top Load Washer Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
