Coleman pac036h1021a service
I have a moblie home. I have a coleman pac036h1021a central air unit that stopped working today. The fan blows but I am not getting cold air and do not feel air coming out of the vents either. I checked to see if it had fuses to replace but I couldn't find any. It had a metal box attached to house. Inside the box is a black square thing with a handle on it that looked like a fuse box. When I pulled it out it it just had copper colored prongs but no fuses. I do not know what that is. I looked online for an owners manual online but couldn't find one.Do you know what might be the problem.
  • Chris Lyon
    Chris Lyon May 11, 2010
    Did everything still sound like it was running, both the indoor unit and the outdoor unit?
    Scholar:
  • 104 Answers
I requested clarification on your problem and did not receive a response. I will assume that you are no longer in need of assistance from FixYa. If this is wrong, please repost your question.
Thank You
Posted on Jun 23, 2008
I submitted a ? Earlier in reference to the igniter on my Coleman central unit w model PAC036H1021A.. My unit stopped blowing heat and was blowing cold air only in the house. It stopped last night and I...
It sounds like you may have electric heat. With that being the case and your description of a burning smell indicates an electrical problem. Since you did get it to start heating it sounds like a possible heat relay problem. I have also found burned connections and I was able to repair them and get the heat strips working again. If you know an air-conditioning and heating technician or electrician you should try to get assistance. The voltage in these units is dangerous and one mistake could only make things worse.
Feb 13, 2015 | Coleman Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
In my mobile home I have a coleman furnace model number 7970-856. It was over 100 degrees today and my furnace fan is stuck running and I don't now if it's supposed to do day. There is no fan switch on the...
There is a fan cycle switch that turns on the fan when the unit heats up (so it won't be blowing cold air) and runs the fan after the unit has shut off to remove heat from the unit. Sounds like it bit the dust. It is located next to the firebox.
Jul 29, 2009 | Heating & Cooling
Central A/C
Hello
This system uses r-22.
By law it will have to be recovered, it can not be bled in the atmosphere. Just FYI. Hope this helps you.
One way to determine what type of refrigirant you are dealing with is to let is set in a system that is not being run for 24 hours and use a pressure temperature chart to determine gauge pressure at said temperature.
Thanks
Zerko
Aug 30, 2008 | Heating & Cooling
Coleman Evron CH/CA unit won't blow the air through the vents
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
May 22, 2008 | Heating & Cooling
Heating & Cooling Logo
262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
