Question about Microsoft Windows XP Professional for PC
During iwas setting agame up the setup ordered me to select bios but there werent any choices to chose nor abutton to browse
  • 1,679 Answers
Was the Game installation complete and you are able to play the game ?
If so, there is no worries.
Most of the PC's automatically setup the bios for the changes done for game setup.
Regards,
Ron
Posted on Nov 04, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
How to giving boot with different ways to acer travelmate 2423 laptop
1) You can set your boot options in your bios, watch as you laptop boots, you should see something like "Hit F2 to enter setup". Hit F2, select boot options then choose to boot from CD, HDD or external drive. Take care because you don't want to mess up your Bios. So read the screen carefully before changing anything. When you're happy, select save and exit then reboot, you should then boot from the device of choice in the order of choice.
2) Windows boot options, windows has several options for booting from, including safe mode. To do this, hit F8 several times while the laptop is booting, you should come to a screen with the several options on offer.
Feb 12, 2012 | Acer Computers & Internet
How do i restore my lenovo 3000 back to factory settings. i have no disks that came with it
Power on the computer and during bootup holding onto F2 key will lead you to BIOS. Browse to Intel AMT. Change the settings to "Disable". Save the settings and exit. After the BIOS settings are saved the system will automatically reboot.On the power on you will see a message do you want to continue.Select yes.You will need to enter Bios again. Browse to Intel AMT again change the settings to "Enable".Press exit saved settings.After the BIOS settings are saved,and powering on the system you will have to press ctrl-P to configure ME/AMT again.Hope this might help.
Aug 18, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
When I power on my Toshiba laptop is tells me to press f2 for SETUP, Press f12 for boot device selection menu. But am not sure what to do after I get on either screen
the one you press are the setup for bios settings..in the boot menu,you will select which is your priority to be your first boot,2nd and 3rd..the first boot you choice will be the one boot first..highlight the boot selection then navigate your choice..if you are going to boot it first from cd drive then select cd-rom,and if you to boot your drive which contains your system,then select hard drive as first boot..
Feb 15, 2011 | Computers & Internet
Why won't my computer boot to the A drive?
Because the BIOS is probably set to boot the hard drive first. The A drive, second or third depending on the boot order set in the BIOS.
Nov 23, 2010 | Computers & Internet
I can't load win xp
check the hard disk option in bios or load bios setup default then check
Aug 25, 2009 | Asrock P4I45GV R5 Motherboard
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
