Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Is it dying?
Lately, I record with timer - can't pull up screen to create top menu or to see what's recorded.. get message that it's playback only but I haven't had a chance to fix it for playing on other machines. I think it sucks. Discs also, blank or just formatted, or suddenly "playback only" although blank. Have had a Samsung where similar problems happened.
  • 70 Answers
If the player is in VCR mode you will get this problem when loading discs, make sure the light on the front shows dvd. It also happens when trying to record form VHS to DVD in the dubbing menu if you are in DVD mode.
Posted on Jul 28, 2008
I have a LOGIK 1TB freeviw Recorder and the following message keeps appearing on screen 'Can't schedule recording. There is already a timer at the same time on this channel.' Ther is not a timer recording...
Check that there is no recording set! Go to Menu and then Library settings and delete anything showing! This should clear the message showing again!
Dec 31, 2014 | Televison & Video
I am unable to playback from the hard drive.
To confirm you really have programs there, record a new short clip and try to play it back.
Aug 29, 2012 | Toshiba Rdxv60
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
My DVR receiver is recording programs that i originally did not put on the schedule. My receiver is also showing the programs in the guide and my daily schedule as "No Info Available". I have...
Hello! For these issues, here are a few simple steps:
First, for the DVR recording shows, you just need to delete those timers. They may have accidentally been set up.
1. Menu, 7-Daily Schedule
2. Timers
3. Edit list
4. Select any timers that you did not create, or want deleted. This will stop them from recording!
For the program guide:
You just need to download the program guide. Here's a couple easy ways:
First way:
1. Pull up the Guide
2. Press 999 then the right arrow button (Browse) until the guide prompts a download,
Second way:
1. Pull up a menu. Press 6 (Sys setup) -1(Installation) - 1( Point dish)
2. Highlight and select Check Switch on the upper right
3. Select test at the bottom left. (If a message comes up between steps 2 and 3, select yes. )
4. Press VIew live tv, and allow the Acquiring signal message and the guide download to go through.
I hope these steps help!!!
Becki Barned
DISH Network Customer Service
Jan 13, 2011 | DISH Network DISH-2800 DTV Receiver
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
DSC L1 is not supporting 4GB memory stick???????????? Says memory card problem
    Please disregard the 'Busy' message which may appear on the LCD screen during MPEG movie recording in VX Fine mode. Recording and playback operations, as well as recorded data, will not be affected.
Sep 26, 2009 | Sony Cyber-Shot DSC-L1 Digital Camera
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Change message
oga recording shortcut... press and hold record... press and release line 1 or 2... release record when finished. or use the menu screens to get to record and playback oga.
Feb 21, 2008 | AT&T EP5962 5.8 GHz Corded / Cordless...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
