Question about Harman Kardon SoundSticks II Computer Speakers
SoundSticks II feedback/buzz/hum LOUD
Out of the blue, my beloved SoundSticks have freaked out.  Ear-shattering feedback has made them impossible to use.  Seems to be affected by movement of the pale green mini plug in my iBook.  Comes and goes mysteriously but frequently.  Are my SoundSticks possessed?!
Same problem...at the beginning i just pull the jack and put back from my cumputer and it was gone, but now after 2 weeks i can heard the hum very strong, any idea? don't say you can through to the bin!!!!! please help!!!!!! thanks
Posted on Jan 05, 2012
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
HI
Time to change sub, or RMS product, for a change, if warranty.
it is a problem with the resistor inside sub.
Posted on Jun 23, 2008
Computer plugs/unplugs Soundsticks II constantly.
Sounds like the either a faulty usb plug or port.
I have had this problem with a couple of usb pen drives.
Are they not still under warantee?
Do they work ok on another computer?
Jul 11, 2010 | Harman Kardon SoundSticks II Computer...
Fan hums when turned on - not when lights are on - only when fan is on - raher loud
On high speeds, they usually do. They have like a vibration sound to them. Have you tried each speed on the fan. With the lights, you're not going to get a humming sound. Only when the fan is on. And yes, usually at the higher speeds (3 speed fan), they do seem pretty loud. I'd have a family member or friend listen and get their feedback before contemplating changing it. Feel free to contact me back with your feedback, and I can help you from there. Good Luck, and I hope this works out for you. - Jim
Mar 25, 2010 | Hampton Bay 52 In.Carriage House II in...
I have just bought some Harman Kardon SoundSticks II. When I plug them into my iPhone, they are perfect, however, I want to use them with an airport express and as soon as I plug them in I get a loud...
this is from Harman support site First you need to determine where the problem is. Try connecting your speakers to another audio source such as a portable CD player. If you receive the proper sonic results, this will tell you that the problem is in the computer and/or soundcard setup. In this case there are many things to try. 1. Interference may be causing the distortion. Please check all surrounding electrical objects and place the speakers away from the problem object. 2. Ensure that the speaker input jack is pushed all the way into the appropriate jack. Check all the connections and secure them. 3. The volume on your soundcard may be set too high. Decrease the volume in your volume control panel. Also check the volume and tone controls on the speaker. 4. Sound card or audio source material may cause a problem. *note* the quality of the audio source is also a factor (i.e. bad recording). The compatibility of your CD/DVD rom drive, soundcard and software will contribute to the quality of your sound.
Good luck
Nov 03, 2009 | Harman Kardon SoundSticks II Computer...
Am getting electrical feedback (droning sound) when I plug in my 2 year old soundsticks. Got any hints?
Check the grounding on the power supply. That eliminates almost all "droning" and "buzzing" feebacks. Try detaching all externally powered accessories to see whether one might be responsible (external hard drives are traditionally the worst, but I got a USB hub once which had a faulty wiring - the droning was the first warning of impending doom).
If this does not work, you can sometimes get rid of some interferences (but usually at higher frequencies than dronings - anyway, it's worth a try) by clamping a ferrite load around the mains wire and/or the DC output wire. Many USB and audio cables will have clip-on ferrite loads which you can unlatch using a thumbnail or a pencil knife, and reuse for your own.
If it's the AC adapter, you might be able to secure a compatible AC adapter that will buzz less. I've found some recovered printer AC supplies from Hewlett Packard to be quite silent electrically (check voltage, wattage and polarity carefully though).
Oct 30, 2009 | Harman Kardon SoundSticks II Computer...
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
No audio from my Harmon Kardon SoundSticks II
mute the inbuilt speakers you can hear the sound from the external speaker
Mar 22, 2009 | Audio Players & Recorders
Hum in speakers
Unplug the minijack from computer to hear if it still hums. If not test speakers at another computer. if it works fine on other computer the sounncard is generating hum noise. Common problem is usually the earthing cable inside the minjack that is touching L or R speakerwire due to bending of cable and breaking off insulation. If youre up to it cut off minijack if its moulde and resolder a new one on.
Oct 26, 2008 | Harman Kardon SoundSticks II Computer...
Soundsticks not recognised
Remember that speakers that plug into an analogue port do not need drivers - the drivers are for your sound card.
I sounds as though the problem lies there.
Jun 30, 2008 | Harman Kardon SoundSticks II Computer...
No sound from subwoofer
You're in warranty. Appers to be a common problem. Soundstixks should either tell you how to fix it or replace your system.
Mar 03, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon SoundSticks II Computer Speakers Logo
868 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
